Some very strange happenings re:my misfire
Posted: Sat Apr 13, 2013 11:01 pm
				Following on from my previous thread regarding my misfire and low compression (http://xdrivers.co.uk/forum/https://xdr ... ic.php?t=5), there have been some developments.
To begin, I had an intermittent misfire - here for a few days, gone for a week, then back again. I tried to fix it by changing plugs and coils but it then got worse!
Faults logged was misfire on cyl 3, even after swapping coils and with new plugs and then new coils, still misfire on cyl 3. This pointed to something more serious in the cylinder. I reset the codes using INPA and the EML will go out for a few days and then return at some point.
A compression test was done at one garage and was found to be slightly lower in cyl 3, so I suspected a valve problem. I didn't want that garage doing any more work (long story) so I took it home an waited for my preferred mechanic to get it in.
He did some diagnostics yesterday, he said that the misfire is definitely intermittent - he did a compression test at one point and there was no loss in compression. He then let it idle for a bit and waited until he heard the misfire (the exhaust on that side 'pops' when it does it) and retested and found slightly lower compression in cyl 3. He did do a leakdown test and found loss on the exhaust side.
He thinks this points to a sticky lifter, due to the intermittent nature of it. He says that if I had a bad valve then the misfire would never go away but in my car, it does go away for upto a week.
With nothing to lose, I put some Wynns lifter treatment in the oil today, really just to see if it made a difference. I also followed the TIS procedure for bleeding HVA lifters which is suggested when a customer complains of an intermittent misfire and/or ticking noise from the engine (I have a little ticking too).
The misfire is now gone again (for now), but now I am getting a new fault:
115 hot film air mass meter
and sometimes the car cuts out as soon as I start the engine. If I restart it it goes into engine failsafe mode and I have to use INPA to clear the fault code and reset adaptations. The next start will work fine but after shutting off it will sometimes repeat this cycle.
If I unplug the MAF completely it just cuts out immediately after starting every single time - nothing done on INPA will get it to start while the MAF is unplugged.
Its all a bit crazy TBF :blink: What is going on?
