fuel injection indicator on dash display
Posted: Thu Mar 28, 2013 12:16 am
by The foolish fellow
this has been on dash for approx 2 years with no discernable other ill effects. with the 1.4.0 scanner i got the following fault codes
56/3c
any ideas ?
LCM  ->  Shadow-memory:
          56/21 - Fuel injection system
          Errors after clear:
          Shadow-memory:
          56/01 - Fuel injection system
Re: fuel injection indicator on dash display
Posted: Thu Mar 28, 2013 7:25 am
2004  3.0d  Facelift
Posted: Tue Apr 09, 2013 10:55 pm
Bump.........
Posted: Wed Apr 10, 2013 8:06 am
by Y13HYA
you ever run low on fuel? If you are able to check live data then have a look at your pre-supply pressure on ignition 2 and then on engine idle.
Posted: Wed Apr 10, 2013 3:52 pm
It was caused by running out ,  But how do I get rid of the fault. If I clear it it comes back right away
Posted: Wed Apr 10, 2013 3:53 pm
by Y13HYA
have you cleared all air out of the system? Take it for a good blast. or there may be a possibility the pump ran dry and has gone weak, but that is rare.
Posted: Thu Apr 11, 2013 3:11 pm
I have this code for over a year now . The car seems fine.
Posted: Tue Apr 16, 2013 11:18 pm
Bump again...... Anyone any ideas ?
Posted: Thu Apr 18, 2013 10:01 pm
by Smeeagain
just a suggestion. Run the scanner, clear the error, do a hard reset of the system by disconnecting the battery. Worth a shot. I've cleared errors in the past that way but not everytime
