	Lowering ....
				Manfromatlantis
Lowering ....
I'm not going to be lowering the X6 ...
I have 15mm spacers on the front and when I turn in full lock the front wheels rub ever so slightly on the oil cooling vents in the front of the wheel arch! However my mate at the body shop is making some new slim line vent covers to eliminate this problem ..... Only happens in full lock when in reverse , it nearly gave me a heart attack !!! Lol
- Don Coffey
				Manfromatlantis
Re: Lowering ....
I was going to lower it using H&R springs and links by around 30-40mm ..... But leaving it as is now.
						- Don Coffey
Re: Lowering ....
Very good.  Did you change your mind between writing the heading and then starting to type in the thread?    )
Don
)Don
				Manfromatlantis
Re: Lowering ....
Ha haaaaa..... yes Don ! Think my mind must be elsewhere for some reason !!!
- Don Coffey
Re: Lowering ....
[quote="Manfromatlantis"]
Hmm, I wonder where.......some neck snapping torque fest somewhere maybe? >:D
Don
Don
				westside
Re: Lowering ....
i had 12mm spacers up front and 15mm on the rears with my 20" set up I had no rubbing when turning.  WIth the 22" i am running a 5mm spacer up front and a 12mm rear again no catching when I turn etc.  Mine is lowered to with no issues
				uplandswayx6
Re: Lowering ....
[quote="westside"]
Westside,
I`m running BMW 20" all round. I`d like to fit wheel spacers all round too.
Wanting to keep the lines but make the look more squat, if that makes sense...Would this 12F and 15R work?
Westside,
Thanks,
uplandswayx6
2011/11 E71 X6 40d
						uplandswayx6
2011/11 E71 X6 40d
				westside
Re: Lowering ....
that would work fine, remember the center bore size is different on the X6 so your need 74.1 and 72.6 I have a set of 74.1 spacers if you would like to buy them
