20" E70 Tyre Change
- 55NF
20" E70 Tyre Change
I'm changing to Non RFT as the ride on RFT with Sport Suspension is shocking. I was told all four tyres have to be changed at the same time, or is this total garbage? Sounds it to me, I only need two fronts
Porsche Macan
Golf GTD MK8
A4 Avant Blk Ed /Merc E350 / X5 E70 40d M Sport / C350 CDI Sport / 335d M Sport / 997 C2S / CLS 320 CDI / E46 M3 X2 / Z3 2.8 / 225 TTC / Mini Cooper JCW / 330ci / 325ci, Pug 205 1.9 GTI, Ren 5 Gt Turbo / Nova Merit
Golf GTD MK8
- Chompers
Re: 20" E70 Tyre Change
Yep bollocks >:D however the tyres must be of the same design/construction on the same axle i.e. change both fronts together and both rears together. Did this on my e61 and no body said anything about doing all 4 together. 2 were done by BMW and 2 by Micheldever.
There is another thread running about informing your insurance company as you are changing the vehicle fro how it was original built. Worth checking with yours I would guess
Current
Previous
Previous
- 55NF
[quote="Chompers"]
That explains it ! just two identical on the same axle. So if you rip a tyre, you;re saying you have to change two? Just looked at the Insurance thread & replied.
Porsche Macan
Golf GTD MK8
Golf GTD MK8
- Chompers
[quote="55NF"]
[quote="Chompers"]
No if you get a puncture or damage one tyre you have to replace it with a tyre of the same construction as the one on the other side of the car and presumably the damaged tyre.
[quote="Chompers"]
Current
Previous
Previous
Not if you're replacing like with like.
It came in when the change from cross-ply to radial was ongoing. As everything is radial these days, it's more about making sure that if you have directional patterns then these are maintained along with speed & weight ratings.
@ Chmoers - you beat me to it..
Never anthropomorphise computers. They hate that.- Chompers
Too much red wine :drunk:
Current
Previous
Previous
davyk31
Mixing runflat on rear with non runflat on front would certainly not be advised. Never heard of it on an X5 but certainly people who did it on 3 and 5 Series reported very odd handling characteristics. You need to swap all 4 at once if going away from runflats.
- Don Coffey
I would agree Davy, I would only consider either run flat or non run flat if all four tyres were changed at the same time.
Don
Don
- Chompers
[quote="davyk31"]
Sorry but that's bollocks!!! I changed my rears to non RFT's 5k before the fronts and had no handling issues what so ever. They were also changed by a BMW dealer who when asked said ther would be no issue what so ever. I would also defy any normal driver to differentiate between the 2 types of tyres in handling terms.
Current
Previous
Previous
- 535dboy
+2
You will have potentially quite different characteristics and if you had to do an emergency stop it could throw the car in a wobble as one end reacts differently to the other
Also are far are the rears actually gone
I used to think it was only ever the fronts that needed doing but if you check the inner edges of the rears you may find they are closer than you think - caught me out a few times
Finally there is the old though thought that too greater variances in treads between front and back can cause transmission problems too
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
2012 Audi RS4 (B8)
Previously :
- 535dboy
[quote="Chompers"]
.... I would also defy any normal driver to differentiate between the 2 types of tyres in handling terms.
...hello
...hello
Currently :
2012 Audi RS4 (B8)
Previously :
2012 Audi RS4 (B8)
Previously :
- Chompers
[quote="535dboy"]
[quote="Chompers"]
...hello
Differentiate between handling is different to ride quality. Changing my 19" RFT's to non RFT's has vastly improved the ride comfort but has had no impact on the handling of the car, infact I would comment that the rear feels more 'planted' than on the RFT's. My non RFT rear/RFT front set up was over the wnter months as well for info.
You are very right to point out the excessive inner shoulder wear. My rears had 3-4mm across the 3/4 of the tyre, however the inner shoulder were :rip: :yikes:
[quote="Chompers"]
...hello
Current
Previous
Previous
leosayer
I can honestly say I didn't notice any handling difference between RFT and non RFT when I changed all 4 tyres on my X5. My X5 handled superbly before and after the change. The only difference I noticed was how much better the car was at absorbing larger bumps.
I don't see how the car could become unsafe with RFTs on one axle and RFT on another, but I'm a bit anal about matching tyres so I would change them all and sell any with remaining tread on ebay.
[quote="535dboy"]
[quote="Chompers"]
...hello
You're disqualified...........you have an......Audi
[quote="Chompers"]
...hello
