Sloppy gearstick
Diz
Sloppy gearstick
Post by Diz » Wed Feb 20, 2013 11:50 am
Hello this is my first post :), have just been to test drive a 2005 x3 3.0d manual with 112.000 on the clock, she runs as sweet as a nut but noticed a bit of slop in the gearstick, just wondering if this is down to worn linkage / bushes or something more sinister ? Can't fault rest of car so could be a bartering point with the seller
Any advice gratefully welcomed
            Diz
Re: Sloppy gearstick
Post by X5Sport » Wed Feb 20, 2013 12:11 pm
Hi and Welcome.
Worn or badly adjusted linkage would be my guess.  It's cable operated IIRC. Mine had no slack in it in all the 6 years I owned it.
Riggie
Post by Riggie » Wed Feb 20, 2013 1:44 pm
I think the autos are cable operated, can't imagine manual would be as well, more likely to be rod bushes, but happy to be corrected.
Post by X5Sport » Wed Feb 20, 2013 2:13 pm
Doh!!  Missed that it was a manual.. :doh:
Don Coffey
Post by Don Coffey » Wed Feb 20, 2013 2:30 pm
Hi Diz, welcome to the forum and hopefully we will be seeing more of you and your new X3.  I would suggest talking to an independent BMW specialist to see what there thoughts are and possible cost of repair.  If you had one close enough to the sellers place I would invest in having them check the car over.  Too easy to let your heart rule your head at this stage and his second opinion would be money well spent.
Diz
Post by Diz » Wed Feb 20, 2013 3:07 pm
Thanks for the replays fellas and the warm welcome :), have asked my local Bm Indy and he has never had one in with that problem before but said it could be as simple as worn bushes or the entire mechanism but without seeing it he couldn't sure, but said to try knock some money off just in case off the worst scenario, so will see what I can make out
            Diz
Don Coffey
Post by Don Coffey » Wed Feb 20, 2013 3:09 pm
Good luck and keep us informed.
Don
Diz
Post by Diz » Wed Feb 20, 2013 3:17 pm
Cheers don will do, it still goes into gear fine and drives well with no noises just not used to the slackness in the gearstick  >:(  as my present BMW e90 330d m-sport has the same miles as this x3 and is as tight as new with the gearstick, fingers crossed for just bushes
Diz
Riggie
Post by Riggie » Wed Feb 20, 2013 5:09 pm
Is the mileage genuine? All my previous cars were manual and all had 100-130k when I sold them and none had sloppy gearchanges.
Post by X5Sport » Wed Feb 20, 2013 5:13 pm
It's possible that a previous owner drove around with one hand resting on the gearshifter, or was a bit 'brutal' with the gear changes.  Either scenario would cause the bushes/pins etc on the linkage to wear and result in some slack.
Diz
Post by Diz » Thu Feb 21, 2013 11:06 am
Mileage seems genuine looking at the old mots and stuff, could be just a rough previous owner, am not too bothered if its just some bushes need replacing as they will probably be quite inexpensive
Diz
Riggie
Post by Riggie » Thu Feb 21, 2013 5:22 pm
Easy enough to do I would think.
shadrack
Post by shadrack » Thu Feb 21, 2013 6:04 pm
[quote="Diz"]
Diz
i re bushed the entire gear linkage on the e30 (though at 26 i thought she deseved it) was about £35 in parts oem, i imagine the x5 linkage will be similar, it was just a few different generic looking plastic bushes, spacers and washers!
current: 2016 Vw Crafter
Diz
Post by Diz » Fri Feb 22, 2013 10:02 am
Cheers for that shadrack  my Bm Indy has said that the bushes and bits aren't that expensive to get like you have put for your e30 that's a reasonable price for the parts
Thanks for the link x5sport that's for your x5 and I'm going for the x3 but am sure they are similar and I will put my details into realoem and look for my model
            Diz
Don Coffey
Post by Don Coffey » Fri Feb 22, 2013 10:20 am
[quote="Diz"]
            Diz
Come on Richard, pick up your game!  You missed it was a manual and then an X3  :doh: as our guiding light we do expect high standards from you  :P
