Hi in the middle of running the 40 Pin & Radio Convertion Extension Lead from the new head unit to the rear of the car (X5 E53 4.6is model) inside more or less totally stripped out down the whole of the passengers side. Does anyone know where in the rear of the vehicle the 40-pin conncetions have to be made?
here's a photo of the type connection block ( there's two in total that have to be connected
thanks
Connection Points for the 40 Pin & Radio Convertion Extension Lead
Re: Connection Points for the 40 Pin & Radio Convertion Extension Lead
Into the quadlock - that is connected to the RCM (Radio Control Module) buried under the spare/compressor/plastic surround next to the battery.
Circled below:
Circled below:
shit that mean's I'll have to lift my LPG tank :wall:
Is the radio antenna/ aerial connection plug/point down there as well?
Is it OK to fit the GPS antenna behind the panelling as it has a magnetic base?
thanks
thanks
I'm afraid - yes, yes and yes.
And you're welcome.
And you're welcome.
If you have OEM sat nav, I would suggest connecting the GPS aerial to the original one in the spoiler. Putting behind the dash does work but is far from ideal and you will have signal issues at times.
2002 4.4 cooking on gas
[quote="Ubatoid"]
I have the pre-facelift model is the GPS aerial in the spoiler on this model also?
Also is the connection point of the OEM sat nav, is it on the back of the original radio unit or in the rear well?
