coding
- xl5
coding
i went to an indy for them to code some items on my x5 but they couldnt do anything with their autologic machine...am i correct in assuming that you can code more stuff with a k+dcan cable and the appropriate software of the web than an autologic will do ...hopefully those with experience can advise..
this is mine , x5 e70 2007 msport
- Steamyrotter
Re: coding
From research --
You can get Scanner 1.4 which apparently works
Or use NCS Expert and a Carsoft Compatible cable
(If going the NCS expert route then NCS Dummy is a good package to use also)
There are loads of guides on line
Google them and you will see
- xl5
Re: coding
i have the cable , so can you confirm that using ncs expert will code stuff that autologic cant ..
Re: coding
You'll find lots of useful stuff on the BMW Coding Forum too if that helps at all
http://bmwcoders.com/
Never anthropomorphise computers. They hate that.- xl5
Re: coding
thanks Richard, i have the cable and have downloaded the software but before i blow myself up i just want to know if the ncs expert software will be able to code my x5 or if it will be the same as the autologic software which wont...
- Steamyrotter
Re: coding
anything that is settable in any module can be coded by NCS Expert
It is what the factory / dealers use.
It is recommended that you use something like the NCS Dummy package also as that gives you a more readable translation of the settings available.
There are lots of write ups on the net but especially useful on :-
http://forums.bimmerforums.com/forum/fo ... fd90&f=233
- xl5
