Both keys have stopped working
B5tew
Post by B5tew » Sat Jan 19, 2013 2:22 pm
Hi guys both of my keys have suddenly stopped working the central locking The car will open manually and starts but both keys are dead and wont even operate the remote boot opening Has anyone got a magic fix before I start ripping the car apart to find the problem
Thanks in advance
Stewart
Sent from my iPhone 5 using Tapatalk
2015 Space grey 30d F15
graemeX5
Re: Both keys have stopped working
Post by graemeX5 » Sat Jan 19, 2013 2:30 pm
Hi i had a similar prob with one key think it was id opened & closed it too often in a few min, poss the battery but if you warm the key on a radiator may help with charge in battery.
Post by X5Sport » Sat Jan 19, 2013 2:33 pm
Mine did this once after a service and battery 'reset' had been done.
I used this procedure under Option 2
Option 1:  To do this procedure you need to have one working key and one key that needs to be programmed.
with the both keys, get in the car and close all windows and doors.
Put working key into the ignition and turn to position 1 (the accessories should turn on)
turn the key back to position 0 and take key out of the ignition.
Using the working key, hold down the unlock button, press the Roundel (lock button) 3 times, and release the unlock button. Doors should lock and unlock.
With the new key, hold down the unlock button and press the Roundel (lock button) 3 times and let go of the unlock button. Doors should lock and unlock and you're done!!
Option 2.  Alternate procedure if above doesn't work or if you do not have a working remote:
Again, with the both keys, get in the car and close all windows and doors.
Place key in the ignition and cycle back and forth between position 0 and position 1 five times very quickly
Remove the key from the ignition
While holding down the unlock button, press the lock button 3 times and then release the unlock button. The doors should lock and unlock to confirm the programming.
If you have another key to program then repeat step 3 for the additional remote(s). The doors should lock and unlock to confirm the programming.
Turn on ignition to finalize
B5tew
Post by B5tew » Sat Jan 19, 2013 2:46 pm
Cheers for the quick replies X5sport I tried option 2 and nothing I think it might be a fuse so will check them and report back later
briankerrys47
Post by briankerrys47 » Sun Jan 20, 2013 11:45 pm
Xoutpost.com Have a post on '(changing batt in E53)?????
B5tew
Post by B5tew » Tue Jan 22, 2013 1:28 pm
Update - I had a quick check of the fuses at the weekend and they were all fine. Then this morning went to go to work and it is all working again all I can think is it must have been the cold or damp got it somewhere and caused it as last week the drivers door jammed and then when it warmed up a bit started working again.
Post by AW8 » Wed Jan 23, 2013 1:29 am
Left my sunroof open overnight...............not good - everything mopped up & working ok though.
Post by X5Sport » Wed Jan 23, 2013 10:18 am
I didn't think we'd had any weather good enough to have the roof open.  Mine's still under 4" of snow.  Only the Mini has been out as it's a manual and the driver has (almost) full control...... :drive:
pvr
Post by pvr » Wed Jan 23, 2013 10:20 am
[quote="AW8"]
Right ...  :o
gchristofi
Post by gchristofi » Wed Jan 23, 2013 12:27 pm
[quote="B5tew"]
If it happens again, may be worth checking the wire of the central locking aerial.  I think this is in the tailgate and can break at the hinge. If so, it can be v difficult for the car receiver to pick up signal from key. This might explain why both stop working at same time. Try moving tailgate and see if keys sprIng back to life.
Gazzi c
Post by Gazzi c » Thu Jan 24, 2013 7:20 pm
Both of my keys have stopped workIng too tried procedure 2 as well with no joy could you please tell me some more info about this receiver in the boot I also have a BMW scanner would the be able to tell me if the remotes are working? Cheers Gaz
E53 3.0i sport, acs foot pedals, acs handbrake lever, acs titanium door handles mirror and fog light inserts, Remus quad exhaust, tinted Windows & E70 3.0 D pretty standard at the mo
gchristofi
Post by gchristofi » Fri Jan 25, 2013 11:30 pm
