ACC - Active Cruise - Works better in France (LHD)
stevee
Just coming back from a French trip, I've noticed that ACC works better on French (or continental) roads .. here's why.
On the continent, when approaching a vehicle, ACC will reduce speed once close, if you then left indicate (to start overtaking) it will immediately accelerates back up to cruise speed essentially ignoring the car in-front. In the UK, overtaking on the right, indicating doesn't do the same .. you have to pull out, wait for ACC to see the road's clear, then it will accelerate.
Seems to me the system is not properly setup for RHD, overtaking on the right ...
S
S
X5 E70 (2011)
Re: ACC - Active Cruise - Works better in France (LHD)
Which side of the car is the radar/sensor on?
If it's the left, then maybe it 'sees' a clear road earlier than if it's on the right and allows acceleration earlier perhaps? Where is the same sensor on LHD cars? It's a theory only though.
Doesn't sound quite right somehow that a left indicator action would cause the car to ignore what is ahead and just speed up.... ???
Bob
Radar sensor on mine is on the right side,i.e. driver's side. Logically that would seem the correct side for a RHD car. No idea if it's different on LHD
Bob
Bob
- 535dboy
It is on the right hand side on my audi and don't have any such problems
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
2012 Audi RS4 (B8)
Previously :
- sramsay
I've always assumed that it was being cautious so you didn't ram someone
Are you sure it's the indicator and not related to the steering position? My experience is its not looking directly in front but the direction of the front wheels? I tend to use it a lot in 30 mph zones and find it does a pretty good job of following cars round quite tight corners - I think at junctions it actually holds the speed and doesn't accelerate.
It's not a cheap option but I'm really glad I went for it.
stevee
I'm sure it's related to indicating. You can try it yourself on a 3 lane road. Approach someone who's in the middle lane and let ACC slow you down, then indicate left (to undertake in the UK) .. you'll then find the car will accelerate whilst it's still in the shadows of the vehicle in-front!
It does make sense, because indicating means you're about to overtake .. so the car automatically speeds up.
S
S
X5 E70 (2011)
- 535dboy
I've only just got mine so I'll try at some point
Currently :
2012 Audi RS4 (B8)
Previously :
2012 Audi RS4 (B8)
Previously :
[quote="stevee"]
S
or turn left or right, or pull-over...in which case it doesn't
S
stevee
if you want to turn left/right or pull over you've got to disable it.
X5 E70 (2011)
- MJim
Just returned from Switzerland - was driving through Belgium and France yesterday in really shi**y weather. Didn't notice the difference but then again I had the gap to car in front set to the max given the woeful driving by many over there - time and again just pulled out when want to overtake without even checking if safe to do so...
Spare: VW Golf V5
History: TVR Chimera 5.0
Spare: VW Golf V5
