Which battery??
awj85
Which battery??
Post by awj85 » Thu Dec 27, 2012 1:34 pm
Taken your advice and looking at the Bosch range batteries.  However, on several websites its coming up the S3 is the compatable one for the 2001 4.4 V8?
Sanj
Re: Which battery??
Post by Sanj » Thu Dec 27, 2012 3:15 pm
S5 is compatible - just the stupid website that can't keep up. I have one in mine.
S3, 4 & 5 are all the same dimensions. 90, 95 and 100 aH respectively and 3, 4 or 5 years warranty.
Go ECP and S5. Search on this forum and you should find a compatible discount code (unless they are currently running offers).
storminmike
Re: Which battery??
Post by storminmike » Thu Dec 27, 2012 7:14 pm
[quote="Sanj"]
I believe the S5 product code on ECP may be 444770198
gmc15
Re: Which battery??
Post by gmc15 » Thu Dec 27, 2012 7:51 pm
Think the ECP code is BATTERY15 for 15% off, but I don't know when it runs out.
x6 M50d
awj85
Re: Which battery??
Post by awj85 » Fri Dec 28, 2012 4:30 pm
apparantly the s5 still only has a 4 year guarantee so ought to get the s4 as its slightly cheaper.  btw battery 15 is no longer valid  ::)
Re: Which battery??
Post by Horizon » Fri Dec 28, 2012 9:27 pm
storminmike
Re: Which battery??
Post by storminmike » Fri Dec 28, 2012 10:08 pm
[quote="gmc15"]
Normally MGRORG25 gets you 25% off at ECP....so if that's better than current discounts and you can wait then perhaps keep your powder dry for those things "not discounted heaavily in the sale"
Taken from an ECP reply as to why a code doesn't work
Hi Guys,
Just a heads up - our current sale let's you save up to 45% off across our entire product range without the need of a promo code..
The forum discount has therefore been discontinued during this period and will resume once the sale comes to an end i.e. 2nd Jan..
source: Yeh I know....rover ::)
http://forums.mg-rover.org/showthread.php?p=5290253
Ubatoid
Re: Which battery??
Post by Ubatoid » Tue Jan 01, 2013 11:37 am
This is what I have in mine http://www.eurocarparts.com/ecp/c/Audi_ ... 0&cc5_1001
I did use the code mbclub25 to get 25% off, but its no longer working. A quick Google should find you a code.
2002 4.4 cooking on gas
dark_stranger
Re: Which battery??
Post by dark_stranger » Tue Jan 01, 2013 7:54 pm
I recently brought http://www.eurocarparts.com/ecp/c/BMW_X ... 4a7&000020 as was having lots of battery issues and this fixed it.  Dont get a lower spec battery just to save a few pounds as you will only wish you had get a bigger one when you still have power issues.
storminmike
Re: Which battery??
Post by storminmike » Wed Jan 02, 2013 8:49 pm
[quote="Ubatoid"]
It's working again
I mentioned above that the 25% discounts were disabled during the sale 8)
S5 works out at £84.55 after 25% off
S3 works out at £68.35 after 25% off
Couldn't find an S4,,,but that's just me
Sanj
Re: Which battery??
Post by Sanj » Wed Jan 02, 2013 8:54 pm
Nice one buddy. We have two codes now for the S5 battery on the following link:
MBCLUK25
and
UKPAS25 (thanks to Jeegnesh)
£84.55 from £112.74, not bad!
storminmike
Re: Which battery??
Post by storminmike » Wed Jan 02, 2013 9:03 pm
[quote="Sanj"]
MBCLUK25
and
my long term favourite MGRORG25 works also too :))
mikem
Re: Which battery??
Post by mikem » Sun Jan 20, 2013 4:15 pm
The 019 S5 has gone up to £130 at ECP now !
It's only £103 at carparts4less though and they've got £15 off when you spend over £100, so £88 delivered.
lynxjock
Re: Which battery??
Post by lynxjock » Wed Jan 23, 2013 12:14 pm
New Bosch S5 just arrived in post, is it a simple change over or do I need to do any programming to match the battery to the car ?
2013 BMW X6 40d, white with vermillion leather
Re: Which battery??
Post by X5Sport » Wed Jan 23, 2013 12:41 pm
Straight swap in the E53.  It's only the later models that need to have the battery coded - and the coding is only so that the car can monitor the 'charging state' of the battery.
Remember to attach the vent hose and plug the unused hole (there should be two options on the S5).
