Driver Door -Help!!
bigsanj
Driver Door -Help!!
Post by bigsanj » Thu Dec 06, 2012 9:06 am
Hi all
The wife has just rang me to tell me she can't close the drivers door.
Any ideas?
X5 4.4 Sport
gmc15
Re: Driver Door -Help!!
Post by gmc15 » Thu Dec 06, 2012 9:27 am
It's probably frozen, happened to mine many a time. I think it will just take time to thaw out unfortunately. I know this won't help your wife at the moment though :(  She could try getting the inside of the car as warm as possible with the doors closed - or as closed as she can get it. I think it is the mechanism inside the door itself behind the handle that freezes, so pouring hot warer on the lock probably won't do any good.
x6 M50d
bigsanj
Driver Door -Help!!
Post by bigsanj » Thu Dec 06, 2012 10:39 am
Well I got to her and she managed to close the door but then wouldn't open.
Got it working now. Was worried she had broken something!
X5 4.4 Sport
gmc15
Post by gmc15 » Thu Dec 06, 2012 10:58 am
Good news :) If the door won't open from the outside don't try and force it as it will break the mechanism inside - well documented problem. If my drivers door would not open easily, I would find one that did, usually one of the back doors and open that and climb through into the front and open the door from the inside :)
x6 M50d
Post by Raj » Thu Dec 06, 2012 11:37 am
Freaked me out 2 Christmas's ago when it happened to me. Ended up dropping the window and holding the door closed and putting the lock pin down to hold it in place.
ianmaney
Driver Door -Help!!
Post by ianmaney » Thu Dec 06, 2012 5:41 pm
Oh the irony of it! This happened to me this morning, bum clenching half hour till it thawed out !!
Current Cars:
X5 06 3.0d Sport (His)
1 Series 116 SE (Hers)
Current Bikes:
GSX-R1000k6 (His)
2010 Suzuki Gladius (Hers)
Don Coffey
Post by Don Coffey » Thu Dec 06, 2012 5:53 pm
Is this an issue that only effects E53s or are the E70/71s effected as well?
Don
scooby1doo1
Driver Door -Help!!
Post by scooby1doo1 » Thu Dec 06, 2012 6:10 pm
Did it to mine last yr and did it this morning as well, usually only takes a few mins if driving and its ok.
As anybody tried in insulate the area affected
Sent from the Iphone via talktapa
storminmike
Post by storminmike » Thu Dec 06, 2012 6:14 pm
[quote="scooby1doo1"]
done it to me too
I think it usually happens when the door is opened and left ajar for a brief moment
DougieV8
Post by DougieV8 » Tue Dec 11, 2012 10:16 am
I sprayed WD40 in the lock and around about it after this happened to me a couple of weeks ago - been ok since. I half expected it again this morning with a frost white car at -4c but all ok.
2002 X5 4.4i Sport
Imy
Post by Imy » Tue Dec 11, 2012 12:46 pm
bigsanj
Driver Door -Help!!
Post by bigsanj » Thu Dec 13, 2012 9:41 am
Cheers for your help guys. Going to try the antifreeze trick. Will let you know how it goes.
X5 4.4 Sport
Lee4.8is
Post by Lee4.8is » Thu Dec 13, 2012 10:34 pm
This happened to me over the two winters I owned mine! I used to have to open the rear doors & climb over & then when I opened the drivers door it wouldn't then shut so I had to drive to work holding the door shut going around corners it just adds to the fun!  :)
The problem I had though was when i got to work the door wouldn't shut properly so I couldn't lock & alarm it so I had to spend ages breathing on the door handle to try to thaw it! Fun & games  :)
Current...E90 330i M Spt Blue/Black  2006
              640d M Spt Blue/White 2012
Previous...
Audi TTS Black 2012
E53 X5 4.8iS  Blue 2004
               E92 M3 White 2009
               E85 Z4 MR 2006
               E61 520d  2009
               E90 330d  2006
               TVR Cerbera 4.5 1998
Rusty
Driver Door -Help!!
Post by Rusty » Thu Dec 13, 2012 11:40 pm
Not had this problem yet, but I keep mine in the garage and use my GSM heater to pre-warm the car anyway :p
Runabout - E92 3 Series Coupe
Lee4.8is
Post by Lee4.8is » Fri Dec 14, 2012 5:38 pm
[quote="Rusty"]
That's the answer keep the X garaged & you won't get the problem  :) at the time I only had 1 garage & the TVR had that,so my poor X had to stay on the drive, we both miss the X5 loads but not the fuel bills!  ;)
Previous...
Audi TTS Black 2012
               E92 M3 White 2009
               E85 Z4 MR 2006
               E61 520d  2009
               E90 330d  2006
