Handbrake Lever
Pete
Handbrake Lever
Post by Pete » Sat Dec 01, 2012 9:21 am
Hi guys,
the X5 is still going strong.  I just wondered how much people have paid at an Indy to get the handbrake lever replaced.
Thanks,
Pete
fenj66
Re: Handbrake Lever
Post by fenj66 » Sat Dec 01, 2012 2:59 pm
Hi, I don't know the answer to your post but just wondered why you need this doing? I  just had a problem with the ratchet mechanism chewing its 3rd and 4th teeth for some unknown reason. I sorted it with a hammer and cold chisel ! :o
briankerrys47
Re: Handbrake Lever
Post by briankerrys47 » Mon Dec 03, 2012 2:54 pm
Dont know about 'Lever' had cable etc replace when a 'ticking' noise appeared it was not releasing pads 'etc'
Pete
Re: Handbrake Lever
Post by Pete » Wed Dec 05, 2012 11:33 pm
Hi, I just took it for a service and the handbrake had been doing pretty much nothing as it was just clicking twice - anything past that point and it just sprang back to the second click point (hope that makes sense). It wasn't able to be adjusted because the teeth had sheered off.  The MOT is due in a week or so, so thought best to get it replaced so it's booked in for tomorrow.
The chisel idea sounds a good cheap fix though!
fenj66
Re: Handbrake Lever
Post by fenj66 » Fri Dec 07, 2012 10:03 am
The hammer and chisel has worked to temporarily reinstate the chewed teeth. Don't know how long it will last for tho.
I would be interested to know the cost of a replacement ratchet mechanism just in case mine fails again...
dinger205
Re: Handbrake Lever
Post by dinger205 » Fri Dec 07, 2012 12:39 pm
shadrack
Re: Handbrake Lever
Post by shadrack » Sat Dec 08, 2012 8:43 am
i wasnt quite so rough as a chisel, this happened on my old x5 i lost 3 teeth so i used a small triangular shaped file and re filed the notches back on  :)
current: 2016 Vw Crafter
fenj66
Re: Handbrake Lever
Post by fenj66 » Sat Dec 08, 2012 10:07 am
[quote="shadrack"]
Yes, that would have been my preferred fix but couldn't find a suitable hacksaw to fit down the narrow lever access. Removing the  trim surrounding the handbrake would be ideal but looked like a lot of work involved.
I wonder if this is a common issue on the x?  :blink:
gav525
Re: Handbrake Lever
Post by gav525 » Mon Dec 10, 2012 12:22 am
Must be common enough as mine is doing it an all and I need to get it fixed before MOT next month! Best I get the chisel sharpened!
2002 X5 3.0i Sport on LPG
