Front and Back Badge Replacement
Front & Back Badge Replacement
My front BMW badge was rather worn and tatty & therefore decided to replace both the front and back badges, but not with the original BMW colour badges, but black carbon badges. Searching on ebay,most sellers were selling the X5 front bagde as 82mm and the rear badge as 72mm/73mm, but the correct size for the rear is 78mm.
Front badge size: 82mm
Rear badge size: 78mm
Tools: Flat head screwdriver, old credit card, sticky pads/double sided tape
Time: 10mins
Front Badge:
The front badge is simply attached to the bonnett with 2 pins on the back of the badge, inserted into 2 holes on the bonnett. You simply have to prise the badge off. I found that placing the card between the badge/bonnett, prevented you from damaging the bonnett with the screwdriver.
Original front badge.
Front badge removed.
Replacement front badge.
Rear Badge:
The rear badge is also attached to the boot with 2 pins on the back of the badge, inserted into 2 holes on the bonnett, but also sticky tape (didnt come with replacment rear badge). You simply have to prise the badge off, with a little bit more force due to sticky stuf. As with the front, I found that placing the card between the badge/boot, prevented you from damaging the bonnett with the screwdriver.
Original rear badge.
Rear badge removed.
Replacement rear badge.
Thats it, quick, simply and maximum effect.
Time: 10mins
Front Badge:
Rear Badge:
Rear badge removed.
Looks good. Can you recommend the seller?
Good quality?
All straight and aligned. I know some on eBay are questionable.
Good quality?
[align=center]2005 4.8is Carbon Black.
All the toys except a heated wheel.....[/align]
Re: Front and Back Badge Replacement
[quote="blofeld"]
Good quality?
To be honest, didnt check,but looking at the pictures, they seem fine & pins all lined up. I got them from an ebay seller called, strangely enough, "badgeman_1232" and arrived within a couple of days, and also received an email from him with a document containing loads of different BMW branded bits,such as gearknobs, etc. The quality of the repalcement badges seems like for like with the originals.
Good quality?
[quote="dark_stranger"]
What on earth were you doing on your bonnet to wear the badge out like that ?? >:D
Spare: VW Golf V5
History: TVR Chimera 5.0
Spare: VW Golf V5
Looks good to me albeit I'm not one for changing OEM designed badges.
Glad the ebayer supplied a decent set.
Sent using Tapatalk
Sent using Tapatalk
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
Tis a straightforward swap over and like the replacements. I know have the all black ones.
Have a set of all black wheel centre caps to sell to.
I bought carbon fibre badges centre caps kidney grilles and steering wheel badge of a guy called Ian Clifton but I'm not sure on his eBay username. All fit perfect and look fantastic
Rear badge removed.
That has just helped me allot as I need to remove my X6 rear badge and it will not budge due to the tape. I can see under it now to see what I am up against.
Rear badge removed.
Ian Clifton *is* Badgeman on EBay by the way
I did have a feeling that is his username, but wasn't 100% sure.
- Rossco0506
badgeman_1232 doesnt seem to be a member on Ebay anymore and all I can find on Ebay are 74mm rear or a pair of 82mm. Anything I have found at 78mm doesnt state that it fits any of the X5's! :wall:
Try Badgeman_123
think that is him. I have certainly messaged _123 before and he has full sets for x5. That was a few months ago mind.
- Rossco0506
Found him, thank you. He doesnt have any for sale on Ebay at the moment but I have sent him an email. Thanks again!
