Starter Motor
fatladandy
Starter Motor
Post by fatladandy » Mon Nov 26, 2012 9:29 pm
I have put a couple of posts up previously about the current drain I appear to have on my 2002 4.4i X5. I can fully charge the battery, use the car for a day then come to it the following day and the battery is completely flat, yet I can also go a week and it be fine.
I have replaced the fsu as I discovered this was faulty and causing the fan to run even when the car was off. however the problem with the current drain is still there. :(
I have search various forums and read about the starter motors failing and pulling a huge current which unless driven miles the alternator can't replace.
On starting the car tonight with a charged battery it seemed to crank quite slowly and laboured. could this
be a sign of a starter motor issue.
Also is the starter motor issue known on the 4.4i, as all the forum posts I can see dont state an engine type.
Andy
Re: Starter Motor
Post by X5Sport » Mon Nov 26, 2012 9:35 pm
Slow cranking was definitely the symptom I had.  It was caused by the starter drawing more current than the battery could deliver (i.e in excess of the 830A CCA).  It was more apparent in cold weather.  I don't know what make the original starter was, but the replacement was a Bosch, fitted under warranty.  Mine was an '05 3.0D Sport Auto.
fatladandy
Re: Starter Motor
Post by fatladandy » Mon Nov 26, 2012 9:40 pm
Well thats a start then, pardon the pun. I think I will have to get it to an auto electrician to test it, if nothing else it will rule something else out.
scooby1doo1
Starter Motor
Post by scooby1doo1 » Tue Nov 27, 2012 10:29 am
You can do a basic test your self if your dash as the hidden menu, I pulled up the volts reading on the dash and was around 12 ish and below when the car was running. Them Figures was with a failing starter motor, now I get about 13.5-13.9 depending on what else is been powered IE lights, heater, fans.
Sent from the Iphone via talktapa
fatladandy
Re: Starter Motor
Post by fatladandy » Tue Nov 27, 2012 10:58 am
How do you get the hidden menu up
Sanj
Re: Starter Motor
Post by Sanj » Tue Nov 27, 2012 11:21 am
[quote="fatladandy"]
Try thislink.
fatladandy
Re: Starter Motor
Post by fatladandy » Tue Nov 27, 2012 7:08 pm
what cca should a 4.4i draw what starting, I have borrowed a clamp meter to test it tonight. the battery in the car was supplied by eurocarparts 3 months ago and is a bosch silver 90ah and 720cca.
fatladandy
Re: Starter Motor
Post by fatladandy » Thu Nov 29, 2012 9:33 pm
well i have tested the car and it draws about 160-180amps on start up so i am ruling the starter motor out, looks like a trip to the auto electrician is in order
