Auto Lights
Posted: Sun Nov 25, 2012 8:19 am
Here's an odd ball that is happening to the 06.
When I first bought the car, on the drive back from Aberdeen I put the headlamp switch onto "Auto". An hour or so into the journey I got a check low beam warning and low and behold, the nearside low beam was out. Once the ignition had been turned on and off both low beams were fine and for the last hour of the jouney they worked perfectly in Auto mode.
Since then the same thing has happened a couple of times so I now just use the lights in the normal way (non Auto) and never had the nearside go out since.
Yesterday I thought I'd try Auto again and within 5 secs I got the warning and the nearside went out. Ignition off, back on and lights switched on normally and back to 2 lights and no problems.
Anyone had this before and can tell me of an easy, cheap fix.
