Bluetooth problems - Fried module or wiring ?
Posted: Sat Nov 17, 2012 11:38 am
by mikem
Anyone have experience of this ?
The phone(s) will no longer connect to the car. Car will go into pairing mode but can`t find the car on any phone, I can still select the Telephone function from the OBD menu but all I get is "activate phone" as obviously nothing is paired.
With the scanner connected I can see "Bluetooth interface error" - have tried a software reset from there but nothing changes - the bluetooth device name and passcode are blank (still has the VIN and SW, HW codes stored though.
I`ve opened the armrest and there are 2 broken wires in there White/Red and White/Green - I can see the pins where they`ve come from in the plug (14 and 4) but on the female side of the connectors thoose pins are empty anyway ??
Anyone have any suggestions or a wiring diagram for the wiring in the harness ?
Posted: Sat Nov 17, 2012 8:38 pm
by ianmaney
Save yourself all the grief of what I personally think is the most useless Bluetooth system known to man and get a Parrot fitted, I did and put the head unit in the ash tray so it can't be seen.
Re: Bluetooth problems - Fried module or wiring ?
Posted: Sun Nov 18, 2012 8:46 am
by mikem
Got to be honest Ian, I retrofitted the OEM Bluetooth to my old M3 and 320d years back as I think it's great. The only think that let's the X5 down is not having VR as its an Assist module fitted. I believe Jochen has a coding solution to this now though.
I had the same parrot fitted in my last daily beater (Astra twintop) and it was OK but not great.
Nobody has a pin out for the X4545 plug that connects the eject box ? Have found loads on the net but none match the coloured wires in mine.
It's under BMW warranty so might have to give up and book it in.
Posted: Sun Nov 18, 2012 2:04 pm
by ianmaney
I've tried time and time again to get my phone paired, I also found broken wires that I repaired but still nothing, it's the only thing I actually don't like about the car.
Sent from my iPad using Tapatalk HD
Posted: Mon Nov 19, 2012 8:02 am
by mikem
Yeah I think the wiring is a Red herring, only 5 wires are needed for the eject box and these aren't the 2 broken ones in my case. So it has to be the module.
I spoke to a friend over the weekend who had exactly the same symptoms and BMW first repaired the wiring then had to replace the module.
Posted: Mon Nov 19, 2012 1:45 pm
by CondorX5
bMw replaced my module under warranty as well - seems there are relatively frequent failures as I have heard of quite a few. its absolutely fine now, touch wood.........
Posted: Fri Nov 23, 2012 7:26 pm
by mikem
Used module from eBay fitted and all working again.
Posted: Mon Dec 03, 2012 3:06 pm
by briankerrys47
E Maney! Parrot rocksĀ  :)
Posted: Mon Dec 03, 2012 3:08 pm
by ianmaney
[quote="briankerrys47"]
Why thank you :)
