cant get breaks to work on rear of x5
ozzyhufc
Post by ozzyhufc » Tue Nov 13, 2012 7:05 pm
x5 failed mot mon as need new break lines on rear all done but got no breaks on rear, now they have been bled and all air locks taken out by garage but still no breaks can anyone help asap someone said its because a abs and dsc
wilkoturbo
Post by wilkoturbo » Tue Nov 13, 2012 8:46 pm
Maybe seazed get a Gclamp in there
bmw x5 le mans blue
ozzyhufc
Re: cant get breaks to work on rear of x5
Post by ozzyhufc » Tue Nov 13, 2012 9:23 pm
no not seazed they were working great before, it need the brake lines change as rusted,now not back brakes not working,and garage dont know what else to do as they have bled the brakes and took or airlocks out still no pedal front ok.
ozzyhufc
Post by ozzyhufc » Tue Nov 13, 2012 9:26 pm
someone told garage its something to do with pump as x5 as abs and dsc, i dont think this is the case please as anyone had this problem after changing brake lines
IanP
Post by IanP » Tue Nov 13, 2012 10:10 pm
If the garage let air get into the ABS pump then you will need a BMW specialist to bleed the system through properly using their fancy machine.
Steamyrotter
Post by Steamyrotter » Tue Nov 13, 2012 10:46 pm
If they did that then they should sort it FOC
Post by Raj » Tue Nov 13, 2012 11:49 pm
The abs valve needs to be cycled and opened using the correct software as this has closed off the feed to the rear lines. No matter what you do the rears won't bleed until the correct procedure is followed to open the valve again.
ozzyhufc
Post by ozzyhufc » Wed Nov 14, 2012 7:53 am
Thanks for that mate looks like i need the bmw people then cost
ozzyhufc
Post by ozzyhufc » Wed Nov 14, 2012 8:19 am
I have just spoken to someone at bmw and they say you dont need BMW specialist to bleed the system through properly using their fancy machine to bleed the rear brakes or plug it in, just bleed them they say,please some help it costing loads.
Post by Raj » Wed Nov 14, 2012 9:03 am
[quote="ozzyhufc"]
That's interesting as when the calipers were re-done middle of last year with the rest if my build thread we went through a fair bit of fluid to try and bleed them and nothing. In the end Jason had to sort.
Ask Jason @ BW off here but pretty sure you'll not be able to just bleed them.
ozzyhufc
Post by ozzyhufc » Wed Nov 14, 2012 10:05 am
Cheers Raj , the garage tell me they are have someone coming round to garage at luchtime with bosh kts kit to open valve to rear brakes and will need alot of dot 4 to bleed, so i dont know why bmw said u can just bleed them, i hope it is sorted today and they dont charge me loads as it been in garage for 3 days now, but at they end of day they should only charge me for new brake pipes as it was there fault they got air into it.
Post by Raj » Wed Nov 14, 2012 12:53 pm
[quote="ozzyhufc"]
Agreed. You've paid them to change the lines. If they have introduced air into the system and have to get an outside source to sort it well that's their own problem. They agreed to take the job on and should have known potential issues that could arise.
Don't let them charge you for the extra costs.
pvr
Post by pvr » Wed Nov 14, 2012 1:02 pm
Removed poll from this post.
To the OP - good luck and as other have said, pay only for the work asked for and not for problems introduced due to the work.
Post by X5Sport » Wed Nov 14, 2012 2:01 pm
The BMW TIS instruction for bleeding brakes with cars equipped with DSC (your is) notes that the BMW Diagnosis and Info System (DIS system) must be connected in order to run through the bleeding correctly.  If they didn't follow this then they messed up, and should fix at their expense as suggested above.
ozzyhufc
Post by ozzyhufc » Wed Nov 14, 2012 2:26 pm
Cheers everyone for the replys i will let you know, i hope to get x5 back today i miss it, and i will let you know how much they charge me for work.
