I fitted my winter wheels at the weekend but I'm not certain what pressures I should be running at. The tyres are 255/50 19 front and 285/45 rear, Vredestein Wintrac extreme non runflats.
I have read that with winters they should be run at slightly higher pressures. Any help appreciated
tyre pressures winter wheels
Ashway
F15 X5 M50d
Aston Martin Vanquish
previous
F37 435d Xdrive GC
F80 M3, E92 M3, 640D M Sport, E70 xDrive30d M Sport, E89 sDrive30i M Sport highline
996 Turbo S
previous
F37 435d Xdrive GC
996 Turbo S
gobiman
Re: tyre pressures winter wheels
I run mine at what it recommends for the size of tyre (on a sticker on front door I think).
I think the point on pressures is as follows (from Blackcircles) -
For every 5°C that the weather drops a tyre will lose about 1 psi of air pressure.
Consequently providing you are checking/adjusting pressures around the right temperature (ie not in a heated garage) you'll be fine.
Others can correct me if I'm missing something!
4.8iS 2004 Le Mans Blue
Z1 1989 Top Red
Mitsubishi Outlander PHEV
Z1 1989 Top Red
