Jacking Pads
MarkyX6
Jacking Pads
Post by MarkyX6 » Tue Oct 30, 2012 5:47 pm
Has anyone used the rubber jacking pads rather than the solid aluminium.
I like the idea of restricting any possible damage, but am not sure if this is actually relevant, bearing in mind that they fit into a slot. One particular seller promotes the rubber version as limiting damage to the plastic socket.
Mark
gobiman
Re: Jacking Pads
Post by gobiman » Thu Nov 01, 2012 11:18 am
I bought a 3 ton trolley jack from Costco (cost around £70) and use it with a rubber ice hockey puck (cost around £5 from ebay). I also have some aluminium jacking pads from US ( about £20 off ebay) that fit into the slots - neat but not really necessary.
I was being charged £20 a corner for bi-annual winter/summer change so worth the investment.
4.8iS 2004 Le Mans Blue
Z1 1989 Top Red
Mitsubishi Outlander PHEV
Re: Jacking Pads
Post by X5Sport » Thu Nov 01, 2012 12:55 pm
I have the US made solid ally type and have not noticed any damage caused to any of ours.  You could always glue a thin rubber strip on top, but the ends have rubber grommets to help them sit better in the slots.
'Damage caused' sounds like a marketing ploy......the Dealers probably use steel ones fitted to their ramps!! >:D
MarkyX6
Re: Jacking Pads
Post by MarkyX6 » Thu Nov 01, 2012 9:55 pm
Thanks guys.
Mark
