tyre pressures for 265/35/22
robzilla
Post by robzilla » Sun Oct 14, 2012 5:52 pm
what tyre pressures should i run with, 265/35/22, 4.4 sport 2003
Re: tyre pressures for 265/35/22
Post by X5Sport » Sun Oct 14, 2012 7:36 pm
Tyre label is on the B pillar. 2.2 bar 31psi is pretty much the norm depending upon load.  22" are a non OEM size, but I would not imagine you need a higher pressure.
robzilla
Post by robzilla » Mon Oct 15, 2012 9:37 am
so basically do i use oem tyre pressures even though these are 22" not the stsndard 19"
Post by Raj » Tue Oct 16, 2012 8:25 am
[quote="robzilla"]
When running the 22" AC Schnitzers I used the OE pressure used for the 20" 168s I had as standard.
robzilla
Post by robzilla » Tue Oct 16, 2012 11:24 am
What are the 20" tyre pressures?
Post by X5Sport » Tue Oct 16, 2012 11:46 am
2.2 bar (31psi) if memory serves - for a 'normal load' in the car.  I think that pressure is common unless the car is heavily laden.
Have a look in the B-pillar, drivers side for the 315/35 wide tyre tread - that's the 20" one for the rear and 275/40 for the font on the same wheel size.
Your tread pattern sounds a bit narrow for 22" tyres?  The 20" are wider = 275/nn front and 315/nn rear with standard 'staggered' setup, but you are quoting 265/nn on 22"?
