Door Protection Stips
Sanj
Post by Sanj » Fri Oct 05, 2012 7:19 pm
So the X goes in for some paint correction and that means the doors will be like new.
Where the car is parked i have brick walls either side, so I would need some sort of door protection. No matter how careful I've been, there's always been the odd occasion where I've messed up!
I'm not a big fan of these door protection strips but do you guys have opinions or links to some half decent ones, considering mine isn't black (grey). Or even some other options - some know I like my towels but they won't work here...  ::)
graemeX5
Re: Door Protection Stips
Post by graemeX5 » Fri Oct 05, 2012 8:09 pm
Hi Sanj had same prob in my garage and so got those garden kneely pads from aldi at 99p each.
They are about 50 mm deep and about 300mm by 450 mm and I stuck them to wall with bonding tube stuff. I have got 5 on each side so covers different heights lengths of doors or different parking options, give good cushioning better than carpet I had before.
Now every time open door i am sure i have no marks, and its green at least in colour,
Black X5
Post by Black X5 » Fri Oct 05, 2012 8:21 pm
Thats what I'd do too- put protection on the wall rather than the car. You don't want to detract from the looks of the car with bump strips! I guess there are probably some sort of horizontal strips that can be screwed to the wall- probably have to do at 2 heights as the front and back doors would have different contact points on the wall.
E70 3.0D SE, Black with Black - Gone but not forgotten!  >:D
storminmike
Post by storminmike » Fri Oct 05, 2012 8:32 pm
[quote="Black X5"]
I went for that D shaped plastic conduit that's cheap on length. The D shape can be unhinged to allow screwing to the wall then clipped it back down. The hollow D shape allows wall distance and bounce
I tried the oval stuff but had to drill 2 holes to let the screw in so as not to protrude....didn't like that
The oval stuff has done 3 winters now
http://www.diy.com/nav/fix/electrical/c ... d=10097159
storminmike
Post by storminmike » Fri Oct 05, 2012 8:34 pm
[quote="Sanj"]
Sanj
Post by Sanj » Fri Oct 05, 2012 9:46 pm
Now you see, you all think the car goes into a garage...
It sits recessed between what used to be a garage, the side of my house and the side of the neighbours, like a car port but without a roof.
When I had the garage (now a playroom) it was carpeted.
I don't think I have anything aesthetic to use......
Post by X5Sport » Fri Oct 05, 2012 9:52 pm
Well you could try a horizontal length of the rubber strip used to cover cables across walkways to prevent people tripping perhaps?
Use this stuff and stick it to the walls?  A bit of Gripfill works wonders.
Post by Raj » Fri Oct 05, 2012 9:54 pm
[quote="Sanj"]
You could carpet the doors and then save on the cost of the respray...lol
Seriously though paaji, what about using the ventureshield paint protection stuff down the edge of the door? It's that rubbery invisible film that is used on the rear wings of the E70 to stop the stone chips.
I had it on the front bumper of my R32 and it was superb.
Post by X5Sport » Fri Oct 05, 2012 9:56 pm
He's got an X5, not a flying carpet....... :)) :))
kkodal78
Post by kkodal78 » Fri Oct 05, 2012 9:57 pm
Why not use one of those invisible protection film that is used  to protect your paint all around? I know toyota uses them on door handles and corners of the doors as you would like to use, on US spec cars
Sent from my iPhone 4S using Tapatalk
kkodal78
Post by kkodal78 » Fri Oct 05, 2012 9:58 pm
I guess i was a few seconds later than RAJ to explain it :)
shadrack
Post by shadrack » Fri Oct 05, 2012 10:05 pm
what about  holdind the interor handle and stopping the door from hitting the wall lol ;)
current: 2016 Vw Crafter
jaynana
Post by jaynana » Sat Oct 06, 2012 7:58 pm
i have thought about fitting a line of used cycle tube along walls.. should work very well actually. issue is i have to do it on my neighbours as well as i park in a shared drive 8)
until then, i have  threatened the whole family with life.. if they don't open the doors with care?  :))
Sanj
Post by Sanj » Sat Oct 06, 2012 9:03 pm
Serious answers chaps. No garage, shared wall with neighbour. No carpet, etc...
Need a good solution for a grey X. If it was black, no issue but I have grey.
Clear protective film will never protect against an inadvertent open against the wall, there's no give on that, the paint will dent under the film...
I need a barrier, hence the strip option thought, unless you guys know of anything else... No matter how much I want the family to be careful, they'll always be that one time they or I mess up...
storminmike
Post by storminmike » Sat Oct 06, 2012 9:12 pm
[quote="Sanj"]
That D shaped plastic trunking I mentioned is bolted to our outside brick wall....it's soft and bounces due to shape deflection. Creates an easy stand off from the brick...can't fault it. Eve if door rides up as you dismount and remove weight the plastic aint gonna wear the door edge
Few screws and rawl flugs....done...no screws on show as the trunking is hinged and clips together. Fllip the top....screw on wall flip down....job done
Hinged and click lock lid for easy fixing
Width across flat surface - 30mm
Height of half round - 15mm
