Urgent - Need a THIN 18mm spanner, where from?
Post by Raj » Thu Jul 19, 2012 12:22 am
Basically started to strip the air suspension out of the X this evening. Control module is out and near side front shock/airbag is out also but the drop link bolt requires a thin spanner to hold the bolt in place so as to be able to undo the nut. Need to pick one up today to carry on.
Anyone?
Thanks.
macky1986
Post by macky1986 » Thu Jul 19, 2012 12:24 am
I would either grind down an old one if you have one or try getting vice grips onto it.
Re: Urgent - Need a THIN 18mm spanner, where from?
Post by Raj » Thu Jul 19, 2012 12:30 am
[quote="macky1986"]
Don't have a grinder and vice grips think are still too wide. Hmm.
weirdfish
Post by weirdfish » Thu Jul 19, 2012 8:15 am
You must have a small engineering shop/garage around you, they will do it for a few bob.
Post by Raj » Thu Jul 19, 2012 8:26 am
[quote="weirdfish"]
Little search has highlighted its actually 11/16" needed for the back of the drop link. Just ordered a new pair of lemforder drop links from ECP with the TEST31 code and will head to Machine Mart to pick up a spanner suitable for the job. Always good to have specific tools...lol
dirtymonkey29
Post by dirtymonkey29 » Thu Jul 19, 2012 8:27 am
Are you able to wedge a flat blade screw driver between the nut and something to stop it spinning?
Post by Raj » Thu Jul 19, 2012 8:47 am
[quote="dirtymonkey29"]
Unfortunately not as it's just way to tight a gap. Tried some pinch grips I had but that ended up popping the rubber boot off... :'( hence now deciding to replace the drop links (but not a bad thing really).
dirtymonkey29
Post by dirtymonkey29 » Thu Jul 19, 2012 10:29 am
Break out the hammer lol
Post by Raj » Thu Jul 19, 2012 11:54 am
That's the first tool that is always brought out at the beginning of any job...lol
shadrack
Post by shadrack » Thu Jul 19, 2012 2:33 pm
while your up at machine mart why not invest in a grinder as well, very useful to have and cheap :)
current: 2016 Vw Crafter
Post by X5Sport » Thu Jul 19, 2012 2:44 pm
[quote="shadrack"]
If nothing else, you can have fun finding the bits 'launched' by the grinder to the furthest corners of your workshop...... :)) :))
Remember to change the head next time you're doing a machine polish though..... :'( :'(
Post by Raj » Thu Jul 19, 2012 4:08 pm
[quote="shadrack"]
Never really needed one before so not sure it's a worthwhile investment at present.
nigelwall
Post by nigelwall » Thu Jul 19, 2012 10:15 pm
I would buy a cheep 18mm spanner and put it on a grinder and grind it to the width I need.
Cheers Nigel
shadrack
Post by shadrack » Thu Jul 19, 2012 10:56 pm
[quote="Raj"]
[quote="shadrack"]
honestly it is, i bought a grinder brand new once for £5 cant remember where from tho :)
Post by Raj » Fri Jul 20, 2012 12:19 am
Sorted thanks to Zamir off here. Got an 18mm cone spanner (kind used for bicycles) from the decent chap at Halfords. £5 deposit and away I go.
Coilovers are here but after a slight mix up and misunderstanding I'm missing a small BMW suspension component which I'm going to have to order in the morning.
