Tyre wear
- malc1950
Tyre wear
Went Under my X today to fit a new PDC and noticed i had tyre wear on the inner of both rear tyres,
hopefully if i get the tracking sorted i should get a bit longer out of the tyres before i have to change them, i had the tracking done 4mths ago at a local garage that does laser line because i noticed a bit of scuffing on the N/S/F tyre outer edge so now i dont know if the rear wear is since then or they sorted it,
2004 3.0d Sport Facelift Remaped, Schnitzer styling body kit, Black leather
Neon lights, Elec fold in mirr, 6Cd changer,DSP, Sat nav, Bluetooth, Wood pack
Speed camera warning, Heated front seats, Wabasto heater, Auto wipers lights, Rear view camera.
Re: Tyre wear
How much wear is there? The rears do run negative camber anyway but depending upon the type of wear then it could be the toe that's out.
- macky1986
Tyre wear
Agreed with above plus was it a proper 4 wheel alignment that was carried out before? A lot of garages I have worked in have all the equipment but most mechanics only know how to do front wheel alignment I.e toe in and toe out. When it comes to rear camber they are clueless.
dirtymonkey29
Tyre wear
Any knocks and bumps from the back? Worn bushes will make it worse
- malc1950
Re: Tyre wear
That is the problem they have these fancy machines but can they use them most of the time NO they cant,
regarding damage i would say no as the car has had one owner before me and i have spoke to him and he told me the car has never been in a accident, think i will google 4 wheel alignment then try to find reviews on the garage then go from there, thanks all
rjkc600
Re: Tyre wear
The standard rear camber setting causes wear on the inside edges. It's meant to be this way to make the car handle better.
If the rest of the tyre is still showing loads of life then you have a problem, and it's possible that some rear suspension wear is causing excessive negative camber.
I had my camber set as positive as it could be to reduce tyre wear, it was still -0.5 degrees so should maintain some of the handling improvements from neg camber.
4.4 V8 2001
- malc1950
Re: Tyre wear
Yes loads of tread left at least 5mm, got it booked in with BMtec Manchester 3rd August when i get back from my holidays, they are doing a full inspection running gear bushes ect, they told me they cant do the rear camber as they dont have the equipment for that , i have found a garage that specialise in 4x4 wheel alignment and rear camber so they are going to sett it all up for me on the 5th Aug, :holdbreath:
- sramsay
Re: Tyre wear
Interesting reading. My E70 with 20" wheels is also wearing significantly more on the inside on the rears. I think they're still okay but not far off.
Car is 2 years old next week but only done 12k.
Worse though was the fronts which I happened to spot the other day. Outside inch has worn out completely whilst the rest of the tyre has loads of depth. I suspect this is unsafe / illegal so will be replacing this week.
Any benefit to going through BMW as opposed to independent?
Pic of front tyre
Pic of front tyre
- DougieV8
Re: Tyre wear
That is still legal - 1.6mm depth limit, over 75% of tyre width. Looks like rest of tyre is well over wear bars.
Alignment needs don though - tyres could be removed and swapped over
2002 X5 4.4i Sport
- sramsay
Re: Tyre wear
Good call. I will ring a few places to see the cost of flipping the front and back tyres. Would be handy to avoid the £1k+ on tyres for a few more months.
- jaynana
Re: Tyre wear
that tyre are prob just about legal but hardly any good.
i've replaced tyres with much better thread.. ..
- sramsay
Re: Tyre wear
In the end I replaced all 4 as the rears had signs of ageing and bad a couple of screws in them - one on the shoulder.
They put the car on one of those laser alignment rigs and it was all over the place and off the scale on one dimension or another on all the wheels! Explains why the wear was so bad given only 12k. Tread depth was 0/6/6 on both fronts.
I haven't had any bad potholes or kerb strikes that would explain it so makes me wonder how well it came out the factory. Given a new set of tyres is £1k+, in future I will consider testing any new car within days and if its out charge the dealer!
- Steamyrotter
Re: Tyre wear
Wear in rear bushes can also contribute to this..
Search for it on here,
To identify it properly you need to deload the suspension by either jacking up under the air spring on the bracket, or just deflating them by undoing the pipe in the boot.
With suspension loaded (even with car jacked up) it will take all the play out and look OK....
There is a video on Youtube showing the difference it makes.
