Extending gravel drive to park a car on area which is currently a flower bed
Posted: Mon Jul 09, 2012 4:21 pm
Front of house consists of 75% gravel driveway laid over concrete. Remainder of front is approx 100 sq ft flower bed. Intention is use existing bed area to be able to park small/med sized car when completed.
I am in process of digging out & neighbour is welcoming deliveries of topsoil.
Materials to hand thus far consist of approx 200 old bricks & various solid concrete & thick/heavy duty old concrete slabs to cover approx 60sq ft (more if staggered).
Plan is to merely make a fairly solid base to lay gravel on same to match pre existing drive.
I had planned to :
1. Excavate existing bed about 6 inches below existing & adjoining drive.
2. Roughly level & compress soil base.
3. Scatter compressed soil with approx 1-2" sand.
4. Compress bricks into base & cover with dry cement mix. (Reasoning for laying bricks loose & not smashing up as hardcore is due to established ground, heavy slabs & occasional/light intended use).
5. Lay carefully spaced slabs on top, (gaps not less than a narrow tyre footprint).
6. Brush over & in between slabs with dry cement before adding gravel, (to reduce ball bearing effect).
N.B. Entire plot is flat. Area to front of new section will remain soil bordered for run off/drainage.
The more I research the more detailed & conflicting advice becomes.
Best end result solution is block pave the lot or get a professional in but funds wanted elsewhere.
I am aware this will be hard physical work ::)
Any advice/thoughts on above appreciated - especially perhaps from x555
I had planned to :
