Electric fan switch
Posted: Sat Jun 30, 2012 1:17 pm
by Frontman
Hi, does anyone know where the switch/temp sender  for the electric fan is, the fan is now on from cold.
cheers,
4.4 '01
And type/part no ?
Re: Electric fan switch
Posted: Sat Jun 30, 2012 4:20 pm
by rjkc600
Is it only on for the first few minutes max?
If so, then thats common and mine is doing it.  The ECU will have logged a thermostat circuit error, I've been told its common and a new thermostat is required which will fix the issue.
My thoughts are that 'ill get around to it' but for now ill let my car sound like a london bus for the first 2-3 minutes of cold start as it heats up the the correct level.
Posted: Sat Jun 30, 2012 6:27 pm
by AW8
I caused replacement of the whole unit albeit a guy I know sorted issues by swapping out the stat.
Posted: Mon Jul 02, 2012 2:03 pm
by jaynana
make sure your ac is off as well. ac turns the fan on.
Posted: Mon Jul 02, 2012 7:56 pm
by Frontman
The fan is on all  the time and aircon off. I have located the sender switch, now trying to find part No, cheers for the replies.
Posted: Fri Jul 06, 2012 8:20 am
by AW8
Iirc when I looked into this there wasn't a seperate part listing for the switch.........Only the aux fan could be bought complete & not cheap.
There was a site where an owner fixed theirs not sure if it wa switch or motor - I believe this was on  an E39 540i....but not a 5 min fix.
