Hi, does anyone know where the switch/temp sender for the electric fan is, the fan is now on from cold.
cheers,
4.4 '01
And type/part no ?
Electric fan switch
- Frontman
Electric fan switch
My Other car's a Hilux Surf.
rjkc600
Re: Electric fan switch
Is it only on for the first few minutes max?
If so, then thats common and mine is doing it. The ECU will have logged a thermostat circuit error, I've been told its common and a new thermostat is required which will fix the issue.
My thoughts are that 'ill get around to it' but for now ill let my car sound like a london bus for the first 2-3 minutes of cold start as it heats up the the correct level.
4.4 V8 2001
I caused replacement of the whole unit albeit a guy I know sorted issues by swapping out the stat.
- jaynana
make sure your ac is off as well. ac turns the fan on.
- Frontman
The fan is on all the time and aircon off. I have located the sender switch, now trying to find part No, cheers for the replies.
Iirc when I looked into this there wasn't a seperate part listing for the switch.........Only the aux fan could be bought complete & not cheap.
There was a site where an owner fixed theirs not sure if it wa switch or motor - I believe this was on an E39 540i....but not a 5 min fix.
