[quote="Turks"]
After reading this I am considering more and more to get my car LPG Converted. Will there be any problems if you have had your car re-mapped? Do Leeds LPG only do Marelli?
I like that the filler can be located where the existing fuel cap is.
If you remove the Spare, do you just need one of them emergency puncture repair kits to satisfy MOT?
Turks.
Not a Marelli system - See pictures. I think one of the reasons that they keep cost down is that they are not buying a full kit but using their knowledge and sources to produce a custom made system for each car. If you look under the bonnet of my brothers 6 cylinder C280 there is a different set up wiith different injection/ecu module etc.
Should be no problems with remapping - They may even be able to do that? They tune up the car using laptop and computer program and part of follow up service (once per year) is to re-calibrate as required.
You will see a drop in actual mpg of around 10% but then you are onto half price fuel
Filler is good hidden away - You have to attach the nozzle each time you fill up, simple screw thread.
Spare wheel can be stored in the actual boot space if you do noot need the room but a can of spray is sufficient - most modern cars have no spare anyway! I have a can of spray stored in the boot, I add the spare wheel if I am going on a long journey.
Oh and check with your insurance company - Tesco took 25% premium increase from me for lpg conversion, my brothers insurance company took nothing!
