pdc sensor
- malc1950
pdc sensor
Today i plugged in my v1.4.0 scanner to identify my faulty sensor, it has shown up the faulty one as the rear off side, are all the back sensors the same or are the two outer ones L shaped where they plug in, as i need to order one off Ebay ::)
2004 3.0d Sport Facelift Remaped, Schnitzer styling body kit, Black leather
Neon lights, Elec fold in mirr, 6Cd changer,DSP, Sat nav, Bluetooth, Wood pack
Speed camera warning, Heated front seats, Wabasto heater, Auto wipers lights, Rear view camera.
dirtymonkey29
pdc sensor
All 4 rears are the same. Two of the fronts are the same too so you have 6 in total all the same. Only the two outer fronts are L shape.
- Sanj
Re: pdc sensor
Second that. If you want to be doubly sure, change the faulty sensor with one of the others and see if the scanner picks it up in the new location.
eBay prices should be £30 and not too much more.
- malc1950
Re: pdc sensor
Thank for the advice, will get one ordered off Ebay tomorrow. :thumbup:
- x555
Re: pdc sensor
agreed with above also
and for easy access seeing as you have a smoker remove the exhaust blanking panel to make the job easier
- malc1950
Re: pdc sensor
i have a rear Schnitzer skirt fitted so i wont be able to go in through the exhaust holes ,
will take a look this weekend,
- malc1950
Re: pdc sensor
When i found the sensor fault with my scanner yesterday i cleared the fault which had been there for
4 to 5 weeks constant , but today i cant get the fault to re a peer ,
could this be because i cleared the fault ,i was going to order my new sensor today but will now put it on hold,
Re: pdc sensor
Might be water ingress related? Has it been dry for the last couple of days?
Never anthropomorphise computers. They hate that.- malc1950
Re: pdc sensor
No the weather here in Manchester has been very wet for the last few days, will see if it behaves over the weekend. :-\
