56 le mans
Fog lights fuses
- wilkoturbo
Fog lights fuses
Hi all does would one fog light stop working if the fues was broke ? Fitted hid fogs all work bar if you fit them to the drivers side !
not checked the fuses as it late now was just hoping for a quick fix many thanks Paul
56 le mans
56 le mans
bmw x5 le mans blue
Re: Fog lights fuses
Not sure about the E53, but it's not uncommon for manufacturers to run the left and right side lighting on different circuits and fuses so one blown fuse doesn't mean you lose the lot, just that side.
This piccie is the front fuse card, but no fog lights marked on it from what I can see....but it is a US card as I haven't found a UK one so far.
Nor does it seem to be on the rear board either...
