can you help my 55plate x5
hi can anyone help just got my 55plate x5 e53 and it squeaks when you go over a bump it sounds like a old silver cross pram,someone said put talc on the bushes do you think this would help please help
Probably a bush needs replacing. I've heard many ideas to prolong life but felt they would all be short term and want to keep on top of the x5 so it doesn't snowball. My advise get it off the ground pull and poke till you find the culprit then change it
2005 X5 4.8is - 1995 Discovery 300tdi - 1970 Series IIa - 2004 CCM 644DS -2000 ZX12r
Re: can you help my 55plate x5
Possible rear balljoint.
Tis possible to DIY if it is that and you have the correct tool.
