Daytime running lights
Bungie
Post by Bungie » Wed May 16, 2012 7:04 am
My near side lights have stopped working and I believe it is a bulb that iluminates the two rings. How the froook do you get in there :headbang:
I presume you need to remove the plastic cowling surrounding the light that is bolted onto the wing.
Anyone changed one before and what about the bulbs ;)
snipez999
Re: Daytime running lights
Post by snipez999 » Wed May 16, 2012 8:10 am
I just changed my 2011 MY X6 40d side bulbs to some GP Thunder 7500 ones. 2 minute job for both sides. Bonnet up, lean head in and see the large circular plastic blanking plate with upturned edges at rear of light assembly. Grab hold, twist a quarter turn and off it comes. You will see the bulb holder directly in front of you. Again a quarter turn and it comes out. Do not touch bulb if it is still in workable order as you can keep it to refit later should you change car etc. Small grey plastic clip on bottom of bulb assembly unclips both sides (careful now these are small and easily broken clips - lift them with a fingernail one by one) and pulls out. In true Haynes style, re-assembly is then the opposite of dis-assembly :-)
I can post up pics if you really need them but it's a very simple job requiring no tools at all.
Post by X5Sport » Wed May 16, 2012 10:28 am
Are they working - in colour terms - and where did you source them from?
I've seen them advertised in the US with postage that was more than the bulbs themselves :headbang:
Post by X5Sport » Wed May 16, 2012 6:51 pm
Apart from the 'corporate design' cue the main beam projector is indeed a fake (more's the pity!). It's just a hole for the H8 angel eye bulb. Good tip about using a tool though... :thumbsup:
storminmike
Post by storminmike » Wed May 16, 2012 7:58 pm
[quote=""X5Sport""]Apart from the 'corporate design' cue the main beam projector is indeed a fake (more's the pity!). It's just a hole for the H8 angel eye bulb. Good tip about using a tool though... :thumbsup:[/quote]
Really :o :o what a waste
I always thought the ultimate would have been 4 dipped and 4 main with each of the lenses doing both duties...imagine that as a hack 8-)
Post by X5Sport » Wed May 16, 2012 8:19 pm
You an me both. There were a fair few people in the US getting very upset about it. Even my Dealer was surprised. There's a noticeable drop in performance compared to the E53 I had before, or even our E46, both of which had 4 working lamps.
carlos50
Post by carlos50 » Wed May 16, 2012 10:01 pm
snipez999
Any pics of the GP Thunder 7500k bulbs please?
535dboy
Post by 535dboy » Wed May 16, 2012 10:05 pm
Even I could do that!!!
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
carlos50
Post by carlos50 » Fri May 18, 2012 6:37 pm
Are they the MTEC superwhite 4350k bulbs? I'd read that at 4350k they would still be quite yellow, how do they seem to you?
