New optional feature for all BMW 5 Series: individualised cockpit thanks to multifunction instrument display.
An optional feature [from July] that will enhance operation of the automobile in all BMW 5 Series models (except BMW 520d EfficientDynamics Edition and BMW ActiveHybrid 5): the multifunction instrument display. This is a freely programmable cockpit display that introduces a new dimension to driver information. Enhanced Black Panel technology opens completely new possibilities for the display of information. Via the high-grade, homogeneous black surface of the 10.25-inch display, the freely combinable instrument integrates significantly more functions than the conventional instrument panel that it is replacing. However, the familiar arrangement comprising four round instruments still remains. Two chrome rings, which open up towards each other, are visible on the black surface. Together with the displays for tank/oil temperature they remain visible on the display even when the ignition is turned off.
With the aid of the Driving Experience Control function, the COMFORT, ECO PRO and SPORT modes can be clearly visually differentiated from one another on the instrument cluster. Whilst in the COMFORT mode a conventional arrangement of four closed round instruments is to be seen, in the modes ECO PRO and SPORT the rings open up to display additional information between the two round instruments. In the ECO PRO mode the rev counter becomes an EfficientDynamics display, showing how efficiently the vehicle is currently being driven. Here the instrument panel shows the extended range based on the adapted driving style. In the SPORT mode speed is only displayed digitally via a large figure in the centre the speedometer, whilst the selected gear is clearly displayed in the centre of the rev counter. Besides changing colour, the displays in the instrument cluster provide additional tailor-made information such as status and function displays, check control and navigation data, all of which can be individually accessed as required. [Hi-res display images directly below].
