Check Oil Level warning
garethdeb
Post by garethdeb » Fri May 04, 2012 4:38 pm
Anyone had this warning come up when the oil level is fine? It popped up yesterday after towing the van for an hour, after I turned the ignition off. Hasn't come back since and the oil level is on the max line on the dipstick.
Any ideas?
Cheers all.
Gareth
Re: Check Oil Level warning
Post by X5Sport » Fri May 04, 2012 4:42 pm
Yes, had it on mine. Oil level sensor was faulty and replaced twice under warranty. Had a similar issue with the oil pressure sensor - and that was changed too. At the time they were both 'known' issues but whether it was a faulty batch or some other reason I was never told.
For the level sensor, it's this beastie in the diesel version.. :)
