PDC issue
entropy
PDC issue
I wish they would have costco size parking spaces!
My PDC sensors don't work on my car. tbh its something I didn't really check when I bought the car.
Would you take this to an indy to fix or something you would do yourself?
if DIY where would you pick the sensors up from?
- jaynana
Re: PDC issue
Abailability all the way from dealer to ebay.
First activate PDC, walk around listening to each to find out which ones have failed.
Its DIY, depending on youe skills, you'll need to take the bumper off.
entropy
Re: PDC issue
Cheers jay
does the bumper come off on the pre facelift model?
does this look like the one
http://www.ebay.co.uk/itm/BMW-PDC-PARKI ... 847wt_1219
- bazzyboy
Re: PDC issue
u can use rangerover 02-06 sensors there £35 from the dealer
u just need to trim a small bit of plastic of inside the multiplug
and they work a treat
Black 3.0d sport
storminmike
Re: PDC issue
[quote=""bazzyboy""]u can use rangerover 02-06 sensors there £35 from the dealer
and they work a treat[/quote]
That's sound cheap for a "real part"...do these fit facelift front bumpers (outer and inner)
- jaynana
Re: PDC issue
[quote=""entropy""]Cheers jay
http://www.ebay.co.uk/itm/BMW-PDC-PARKI ... 847wt_1219[/quote]
assuming its the font.. (pls find similar instructions for the rear) check this out, actually TIS says to just pull the sensors out:
http://tis.spaghetticoder.org/s/view.pl?1/05/75/54
i'm sure its easier with the bumper out though..:
http://tis.spaghetticoder.org/s/view.pl?1/09/13/67
dirtymonkey29
PDC issue
Does say on that link up to 2003.
From 10/2003 preliminary task - remove front bumper trim. Which is correct. Facelift bumper needs removing pre facelift doesn't
entropy
Re: PDC issue
Just want to say thanks for this!
Got it sorted tonight. its was rear drivers side sensor. I popped it off and had some mud and then sprayed something to clear the connectors and plugged in and worked!
My indy garage wanted £87 to diagnose the fault plus £100 for sensor etc. Doubt he would of tried cleaning the old one either.
So am very happy although i did break that outer casing of sensor.
Benxwyatt
Re: PDC issue
Hi mate, this sounds the same as wot mine r doin, same sensor aswell, how do they come out? Might try the same trick coz some days they work so maybe not frigged altogether?!
X5 3.0d sport
entropy
Re: PDC issue
Hi Benxwyatt,
The Plastic cover on the sensor just pops off and then I pushed the sensor through hole and and it came through the gap by the exhaust.
I used a small flat head screw driver to pop the plastic cover off but be careful as I snapped one of the clips on it and it made it difficult to get back on afterwards.
My sensor was just covered in mud and once cleaned it started working straight away.
My indy wanted £88 to diagnose plus £100 for sensor plus extra £50 to fit it. So it def worth trying to do yourself.
If I can do it should be a doddle anyone else as i'm rubbish at fixing things
Benxwyatt
