WHY DOES MY X5 STILL SMOKE ALOT SOMTIMES
ozzyhufc
Post by ozzyhufc » Mon Apr 23, 2012 9:24 pm
MY X5 STILL SMOKE'S BAD SOMETIME'S ON START UP SO DAY'S IT USED TO BE LOADS AND U COULD NOT SEE CAR'S BEHIND BUT TONIGHT I WAS WARMING UP MY X5 AND IT REACH IT'S TEMP BUT WAS STILL SMOKING ,AFTER A GOOD LITTLE RUN IT'S OK, I HAVE DONE EVERYTHING POSSIBLE LAST THING IT COULD BE NOW IS THE TURBO BUT IT DRIVES ACE, ANYONE HELP PLEASE IT SMELL BAD AND THE MRS MOANS ABOUT IT, IT SMELL ABIT LIKE A GAS SMELL AND IT IS WHITE SMOKE, A FRIEND SAID TONIGHT HE SEEN A BIT OF BLUE SMOKE , BUT I DID'NT, CAN ANYONE HELP WITH THIS, MY X5 IS A 3.0D 2002 MANAUL.
ozzyhufc
Re: WHY DOES MY X5 STILL SMOKE ALOT SOMTIMES
Post by ozzyhufc » Mon Apr 23, 2012 10:22 pm
can a bad cat course the smoke, or is it the turbo
shadrack
Post by shadrack » Mon Apr 23, 2012 10:27 pm
is it using oil or water??
current: 2016 Vw Crafter
dirtymonkey29
Post by dirtymonkey29 » Mon Apr 23, 2012 10:35 pm
Any fault codes? Get it to an Indy for proper diagnosis. Guessing and changing out parts until issues are solved get expensive.
ozzyhufc
Post by ozzyhufc » Tue Apr 24, 2012 8:33 am
No does not lose any water but does use a bit of oil after so many miles but i was told that is normal....
dirtymonkey29
Post by dirtymonkey29 » Tue Apr 24, 2012 9:31 am
Mine doesn't lose any oil or water. 3.0d 54 plate.
Could be as simple as a leak dripping onto exhaust or could be as bad as piston rings. You really need to let someone take a look.
ozzyhufc
Post by ozzyhufc » Tue Apr 24, 2012 8:31 pm
Its been to bmw a few times and other garage's but it never doe's it there and they say all is fine, its got to be something, like turbo leaking oil when standing maybe that's why its there when you start firts drive, after that is fine all day and next day. then it come's back now and a again.
dirtymonkey29
Post by dirtymonkey29 » Tue Apr 24, 2012 10:19 pm
Then I'd be leaving it with them overnight for a few days and taking the courtesy car
ozzyhufc
Post by ozzyhufc » Wed Apr 25, 2012 8:19 am
BMW HAD IT FOR A WEEK ONCE AND THEY SAID THEY USED IT ALL WEEK AND IT WAS FINE, THEY USED A TANK OF FULL AND STILL CHARGE ME FOR LOOKING AT IT, BMW ARE A JOKE!!!!!!!!!!!!!! THEN THEY ASK ME WHAT DO U WANT US TO DO NOW, AND I SAID WHAT U BUILT THE CAR U TELL ME!!!!!!!!!!!!!!
Post by X5Sport » Wed Apr 25, 2012 10:20 am
[quote=""dirtymonkey29""]Mine doesn't lose any oil or water. 3.0d 54 plate.[/quote]
Just for your ref, BMW have said that you can expect to use up to 1 litre every 2,000 miles or so. Mine used oil when it was new but as the miles went on the oil consumption dropped away to nothing. Some continue to use oil. Yours is one that like mine stopped using it.
The X6 uses none (so far) as the emissions controls are tighter now.
jaynana
Post by jaynana » Wed Apr 25, 2012 4:39 pm
[quote=""X5Sport""][quote=""dirtymonkey29""]Mine doesn't lose any oil or water. 3.0d 54 plate.[/quote]
The X6 uses none (so far) as the emissions controls are tighter now.[/quote]
interesting. i thought as engines wear out they start to burn more oil. although yeah they would need to settle in first and before settling in they prob burn oil too.
dirtymonkey29
Post by dirtymonkey29 » Wed Apr 25, 2012 4:42 pm
Must be lucky then
andyr81
Post by andyr81 » Fri May 04, 2012 12:52 pm
Have you checked your engine breather filter? might be getting blocked up and forcing oil through turbo? ive had same problem, just mine went all of a sudden!
Bargain Bucket
Post by Bargain Bucket » Fri May 04, 2012 1:02 pm
How do you check the vortex style one? I pulled mine out the other week (oo-err) and it looked clean enough but how can you test if it is actually clean inside? I couldn't work out how it actually works (although I only spent a couple of minutes looking).
BMW X5 3.0d M-Sport facelift (E53).
andyr81
Post by andyr81 » Fri May 04, 2012 1:14 pm
mine didnt have the vortex style fitted, just had the standard foam type, but it was blocked solid, unfortunatly the damage was done, turbo recon, clean intercooler, im still on with it now, but i think the intake manifold may be damaged now because im still getting white oily smelling smoke, need to get it off and check.
