Toys in your car cable
wilkoturbo
Post by wilkoturbo » Fri Mar 23, 2012 12:31 pm
Hi all bought the cable fitted in reverse cam and rear screens all done but I've bought an iPhone av cable if I plug it into the av in on that cable how will I get the sound out the nav ??
bmw x5 le mans blue
wilkoturbo
Post by wilkoturbo » Fri Mar 23, 2012 4:23 pm
bmw x5 le mans blue
Re: Toys in your car cable
Post by X5Sport » Fri Mar 23, 2012 4:34 pm
Pass. I had the official 3.5mm adapter system in the glovebox. That worked via Aux. No control of the idevice possible though.
wilkoturbo
Post by wilkoturbo » Fri Mar 23, 2012 5:45 pm
O how do u get aux on the screen ?
bmw x5 le mans blue
Sanj
Post by Sanj » Fri Mar 23, 2012 6:18 pm
Select Television and AUX is the last channel.
Let us know if it works. Usually the Apple products are too low a signal to work.
wilkoturbo
Post by wilkoturbo » Fri Mar 23, 2012 6:37 pm
Av ??? So I'll have to have a blank screen ???
bmw x5 le mans blue
Sanj
Post by Sanj » Fri Mar 23, 2012 6:41 pm
Unless the video from the iPhone will work... if you play videos. Otherwise audio will just be that, a blank screen.
Get an Intravee and be done with it! :P
wilkoturbo
Post by wilkoturbo » Fri Mar 23, 2012 7:25 pm
Lol there £200 plus and not sure what or if I need !?
bmw x5 le mans blue
Post by X5Sport » Fri Mar 23, 2012 7:36 pm
If you want full control of the idevice then as Sanj says you will need an external solution. The only limited support BMW provided when I bought mine was a cable that plugged into the Aux port on the back of the Nav head and allowed connection via the iPod headphone socket into a 3.5mm stereo jack socket in the glovebox. I think that cable is still available. I have a copy of the BMW fitting instructions in PDF format but will need an email address to send them to you as we can't attach said documents (Mods - that's a hint :poke: )
BMW did not provide an integrated OEM solution until much later models appeared and the right options were in the car. I had an Ice>Link plus in my E53 which when it worked was great, but it meant I lost use of the CD multichanger. When it wasn't working nicely then it was a mare to get it working nicely again and product support was awful being based in Eastern Europe.
There is a US based DICE option but I have no experience of their products with the E53. Support is however supposed to be much better.
Sanj
Post by Sanj » Fri Mar 23, 2012 7:48 pm
Support of the Intravee is exemplary - it's British! :thumbsup:
And then you get all the extras too. No messing, it does everything you expect (all on the screen and through the steering wheel controls too).
You should know better than to ask what you need btw! You've been on this forum long enough! Search button you tart!
An Intravee and the Apline KCA-420i (with both cables) is all you need. From new they will NOT have the Extras firmware, you'll need a friendly forum member... :whistle:
Post by X5Sport » Fri Mar 23, 2012 7:59 pm
And I bet Sanj can do some negotiating for you too...... :poke: :rofl:
X5Driver
Post by X5Driver » Fri Mar 23, 2012 8:02 pm
Sanj what is the alpine kca420i bit for exactly does everyone need this.
2005 X5 4.8is - 1995 Discovery 300tdi - 1970 Series IIa - 2004 CCM 644DS -2000 ZX12r
Post by X5Sport » Fri Mar 23, 2012 8:08 pm
CondorX5
Post by CondorX5 » Fri Mar 23, 2012 8:15 pm
I have a spare KCA420i........
wilkoturbo
Post by wilkoturbo » Fri Mar 23, 2012 8:30 pm
Spare ??££??
bmw x5 le mans blue
