iPhone 4 and blue tooth
scooby1doo1
I was bored waiting for the wife, so just started playing with the BT so far I have found the car and the code.
The problem is, is then says connected, but a few seconds later says on the iPhone not connected.
Any body give any info.
Sent from the Iphone via talktapa
- pvr
Re: iPhone 4 and blue tooth
Did the system go through the pairing process on the navigation screen?
scooby1doo1
I don't no I did it through intravee, is this the wrong way.
Not sure about doing it through intravee but may be worth pairing through the OE system and it may then just connect through intravee each time.
scooby1doo1
Ok I will check doing it that way, what do I do though.
It's something like press and hold the button in the armrest for 3 seconds then whilst it's still pressed turn key to ignition 1 and continue to hold for another 3 seconds then when you release the screen should show as pairing and you then put the code into the phone. Once paired turn ignition off and should be sorted.
scooby1doo1
Ok ill check and have a play later, want really bothered as I was just messing while bored.
Cheers though
Cheers though
RichardP
Try deleting all text messages from our phone, with some versions of the Bluetooth ULF they can cause this type of behaviour.
scooby1doo1
Ok cheers
Will try that, the other post just seems to do the same connects then says discounted within a second or 2.
