Hi all
Further to my recent post about issues with this I have a warning back, the last scan by BMW indy (im waiting for my bmw scan tool 1.4.0 thingy)  said it was an over pressure in the accumulator.  Any ideas?
	Active Susp Inac
- X5Driver
Active Susp Inac
2005 X5 4.8is - 1995 Discovery 300tdi - 1970 Series IIa - 2004 CCM 644DS -2000 ZX12r
Re: Active Susp Inac
The accumulator could well need replacing but it could well be the pressure valve instead. As well as most of the rest of the system on mine this was also replaced. Cost about £250ish from memory for the accumulator.
- X5Driver
Active Susp Inac
Are these parts testable or is it a case of most likely / cheapest first till you hit the right bit. Getting the BMW scanner will this help me narrow it down?
The scanner may help but I found out it was a bit of trial and error and guesswork even from the dealers.
- X5Driver
Active Susp Inac
Cheers for that Raj, I'll give it a go when it arrives
