				Check park lights
				Posted: Sun Mar 04, 2012 2:27 pm
				by Pradaman
				Have this message displayed on dash of my 55 plate 3.0D . When I lock the car with lights on the drivers side front indicator stays on!!!!! Strange!
Any ideas??
				Re: Check park lights
				Posted: Sun Mar 04, 2012 3:08 pm
				by petert
				Check you've not got the indicator stalk in the 'off-centre' position.  Might be the parking light.  (not 'side-lights' via the main light switch)
Peter T
				Posted: Sun Mar 04, 2012 10:49 pm
				by Smeeagain
				As the message says "check park lights" have you tired checking the parking lights? I had the same message, with the same indicator symptom - it was the offside parking light bulb that needed changing (hence the message) - its something to do with the bulb tripping out that activates the indicator (I think to show you externally that there is an issue - or perhaps comes on to provide a parking light in the absence of the faulty one?
				Posted: Mon Mar 05, 2012 11:59 am
				by pvr
				Correct, when sidelight is out the indicator stays on.
				Posted: Mon Mar 05, 2012 12:13 pm
				by gobiman
				Had this problem with new Angel eyes. Loose connection and needed pushed in a bit harder.
				Posted: Mon Mar 05, 2012 5:04 pm
				by Pradaman
				It is a sidelight bulb out cheers for the replies. It has angel eyes does the headlight have to come out to change bulb?
				Posted: Mon Mar 05, 2012 5:35 pm
				No.  Bulb access is on back of the lamp unit.  It's under the sloped rear port cover if I remember correctly.
