Check park lights
Pradaman
Check park lights
Post by Pradaman » Sun Mar 04, 2012 2:27 pm
Have this message displayed on dash of my 55 plate 3.0D . When I lock the car with lights on the drivers side front indicator stays on!!!!! Strange!
Any ideas??
petert
Re: Check park lights
Post by petert » Sun Mar 04, 2012 3:08 pm
Check you've not got the indicator stalk in the 'off-centre' position. Might be the parking light. (not 'side-lights' via the main light switch)
Peter T
Smeeagain
Post by Smeeagain » Sun Mar 04, 2012 10:49 pm
As the message says "check park lights" have you tired checking the parking lights? I had the same message, with the same indicator symptom - it was the offside parking light bulb that needed changing (hence the message) - its something to do with the bulb tripping out that activates the indicator (I think to show you externally that there is an issue - or perhaps comes on to provide a parking light in the absence of the faulty one?
Smee
pvr
Post by pvr » Mon Mar 05, 2012 11:59 am
Correct, when sidelight is out the indicator stays on.
gobiman
Post by gobiman » Mon Mar 05, 2012 12:13 pm
Had this problem with new Angel eyes. Loose connection and needed pushed in a bit harder.
4.8iS 2004 Le Mans Blue
Z1 1989 Top Red
Mitsubishi Outlander PHEV
Pradaman
Post by Pradaman » Mon Mar 05, 2012 5:04 pm
It is a sidelight bulb out cheers for the replies. It has angel eyes does the headlight have to come out to change bulb?
Post by X5Sport » Mon Mar 05, 2012 5:35 pm
No. Bulb access is on back of the lamp unit. It's under the sloped rear port cover if I remember correctly.
