Page 1 of 3
X5 2002 4.6is sat Nav and sound problem
Posted: Sat Feb 25, 2012 7:01 pm
by Moh153
brought an x5 4.6 2002
As the title I'm having difficulties finding sat Nav option on the screen
I've disconnected the battery for a few mins connected back up and still the same
The screen is also blue but I'm sure it doesn't be blue
Another problem is it has DSP and only one speaker works and some tweeters and the standard subwoofer crackles
Any advice please
Thanks in advance
moh153
Re: X5 2002 4.6is sat Nav and sound problem
Posted: Sat Feb 25, 2012 7:14 pm
by Sanj
Look in the boot on the left-hand side and pull the cover off. What's in there?
Usually a 6 disc changer and the MK3 satnav unit - reckon yours is missing/disconnected.
Search RCM/Radio Control Module/BM24/BM54 for answers to the speakers poor functionality.
Posted: Sat Feb 25, 2012 8:56 pm
by Moh153
Hi sanj thanks for the reply
The sat Nav unit in the back is there and a cd inside and comes on with red light showing to
Regarding the bm54 I might send that of for life time guarantee repair
Posted: Sat Feb 25, 2012 10:08 pm
by Sanj
Disconnect it, see if you get any changes. Then re-connect.
May work - no satnav is usually the unit on the blink... Also ckeck associated fuses in the front AND back.
Posted: Sat Feb 25, 2012 10:58 pm
by Moh153
Looks I might need a new unit then sanj
As already tried disconnected and reconnected and checked fuses on front but in the back I don't know of there is any on the back
Also sanj is the front screen supposed to be blue?
Posted: Sun Feb 26, 2012 12:13 am
by dirtymonkey29
Where are you based? Maybe someone with a fault code reader or navcoder can do a scan for you to see if there's any issues
Posted: Sun Feb 26, 2012 4:17 am
by Moh153
I'm based in Birmingham mate I wouldn't mind travelling either to get a better idea of problem
Posted: Sun Feb 26, 2012 8:56 am
by Sanj
[quote=""Moh153""]Looks I might need a new unit then sanj
Thanks[/quote]
It would be good to get a scanner on there to check if the problem is further down. The screen going blue is because the car thinks there's no SatNav unit attached.
So, yes - could be a SatNav gone wrong or again fuses, double, triple check. One's in the back are to the right-hand side storage area (where your sub is, I think - above). Not sure if any are to do with the SatNav but check.
If possible, best way would be to try swapping the unit out with a known working one.
Near you is a member called Raj. He may get his scanner shortly and even have a MK4 unit for sale (best to get the MK4 over the MK3 if finances permit), drop him PM.
Posted: Sun Feb 26, 2012 2:03 pm
by Moh153
What's the difference between mk3 and mk4 sanj?
Posted: Sun Feb 26, 2012 3:29 pm
Mk3 is a CD based system. Mk4 uses a DVD so holds more information.
Posted: Sun Feb 26, 2012 3:49 pm
by Moh153
Thanks sanj you've been alot of help mate
In regards to the bm54 does a bm54 come in the newer x5 2010 model?
Thanks aswell x5sport
Posted: Sun Feb 26, 2012 5:07 pm
by Sanj
Being DVD based means more info and quicker operation speed (if you take the wrong turning, it's quicker to re-work a new route).
Plus there are other 'unofficial' extras we don't talk about on a public forum.
Get a like for like unit to check if your one is duff.
BM24 or BM54 are the Radio Control Module. 24 for the older cars and 54 for the face-lift cars for sure (think cut-off to newer BM54 was 2002). It is for all 2000 to 2006 E53 type X5's. Notorious failure issue...
Posted: Sun Feb 26, 2012 5:51 pm
You will get TMC data on the Mk4. TMC very handy for re-routing around problems - with some 'interesting' routes sometimes chosen!! Not sure if this was included in the Mk3 - Sanj might know. Mk3 CDs were only capable of holding a single country like UK, whereas the DVD gives you the most of Europe to explore on a single disc.....should you want to that is.
Posted: Sun Feb 26, 2012 6:33 pm
by Moh153
Thanks for info guys
Well borrowed a mk4 from an BMW e46 m3
And works perfect in regards to the sat Nav so mine is duff
Mine is definately a mk3 unit
by pvr
MK4 also supports 3d-type view with software version 28 onwards, which is nice.
