Video of TV problem...
Posted: Sun Jan 29, 2012 4:57 pm
by UrbanFlow
I posted about this problem a few months ago and several people thought upgrading to a digital tuner might be the solution, but I'm hoping someone might watch this and say "oh no... you just do A, B and C and it'll be fine"!
Anyway, long and short of it is - everything works fine - I can get a TV picture but the sound is just one long pitched wail.
CLICK THE IMAGE BELOW FOR VIDEO...
Any ideas? Or do I need to start spending again?!
Re: Video of TV problem...
Posted: Tue Jan 31, 2012 10:19 am
Ouch! Keep your volumes down, that's a great wake up tone. :D
Not good. Apart from checking all the plugs are in, I suspect that one may need some work. The tone came up instantly and before the image.
Posted: Fri Feb 03, 2012 9:26 am
by Nat_h
Try adjusting the sound settings.
Mine did this once, when the bass was set quite high.
Decreasing the bass, stopped the noise.
HTH
Posted: Fri Feb 03, 2012 11:04 am
by UrbanFlow
[quote=""Nat_h""]Try adjusting the sound settings.
HTH[/quote]
Thanks, I'll try that.
I'm going to investigate the module again in the boot this weekend too.
Posted: Sat Feb 04, 2012 8:43 pm
by UrbanFlow
UPDATE:
So I fiddled with the BASS and Treble settings whilst in radio mode and found a bizarre anomally - Treble works fine, but If I set BASS below the halfway marker I get the same horrible high pitch wail I get in Television mode (as in Video above).
So I'm starting to think the problem is more to do with the amp...?
Any thoughts peeps?
Posted: Sun Feb 05, 2012 2:32 pm
by jaynana
that sounds like feedback, is there a mic coming into play in whatever you've done?
Posted: Sun Feb 05, 2012 5:35 pm
by UrbanFlow
[quote=""jaynana""]that sounds like feedback, is there a mic coming into play in whatever you've done?[/quote]
Only mic in car would be the bluetooth comms pack for the telephone - which works fine, no feedback when using that.
Posted: Thu Feb 16, 2012 5:53 pm
by Giles90
how is your tv working without a digital tuner? isn't analogue turned off?
Posted: Thu Feb 16, 2012 8:49 pm
by jaynana
analogue is still on. switch-off is staggered. in london its april, 2012.
Posted: Wed Feb 22, 2012 5:41 pm
by UrbanFlow
Ah, so in April I lose everything - sound and picture!
Phooey.
Posted: Tue May 29, 2012 1:38 pm
by UrbanFlow
UPDATE ON THIS PROBLEM
My whole area is digital now - weirdly I can still get a perfect TV picture for every channel in the X5 - but still the high pitched squeal.
ALSO...
Just discovered that I can only get FM radio stations.
All my AM and long wave stations just squeal like the TV.
Tried to tune into 5 live sport for the grand prix and got SQUEALLLLLLLLLLLL!
Time to buy a new unit?
Posted: Tue May 29, 2012 7:48 pm
by Sumo69
I had issues with no AM and FM - a new amplifier courtesy of my AUC warranty has sorted that so that may be where your problem is.
David
