Hualigan / Dynavin install OEM Nav
How-To articles ONLY go here.
Ubatoid
Post by Ubatoid » Fri Jan 27, 2012 10:22 pm
Just thought I would record the process of installing my Hualigan into my 02 X.
First problem is that due to having the OEM nav system, the connections to the car have to be made in the boot where the RCM is next to the battery. Next we have to find out if we need the later 40 pin lead or the earlier 17 pin. My build date was 12/2001 which it seems is a grey area as far as the 40/17 pin question goes, but thanks to Rob at Icebox auto who agreed to send both leads and just send back the one I didnt use (top tip N1K85 :thumbsup: )...... Next problem is this on my car......
Thats right, a woofing great LPG tank covering everything I need to get at. As luck would have it, the LPG installer had thought ahead and put a long flexy hose on the filler connection marked in yellow in the following picture. The feed to the engine is safe to disconnect as it is closed off when the ignition is off by the valve indicated by the red arrow. The tank is held down by 4 easilly accesable bolts on the top, these where removed and with a bit of pulling I was able to wrestle the tank onto the tailgate to give access to the battery compartment.
Red arrow is the new extension lead that goes upto the new head unit. Yellow arrow is the existing loom that plugged into the RCM. Purple arrow is where the BUS module plugs in - not shown here as at the time the picture was taken, I didnt have it. :cry: Also worth mentioning that the aerial has to be extended back to this area and plugged into the aerial lead that originaly plugged into the RCM as indicated by the green arrow.
The extension cable was passed through the backseat area along the line of the battery cable ( Thanks Sanj ;) ) to exit under the rear seat on the left hand side....
removing the lower rear seat revealed a lifetime of sweet wrappers, fossilied chips, £2.60 in change ( put towards the SMG steering wheel fund) and a scorecard for Wentworth Golf Club.
The cable was then routed along the line of the left hand sill upto the centre of the passenger seat and then across under the seat to the centre consol, along the side of the centre consol and up to where the head unit will be when it arrives. I found it easier to remove the passenger seat to lift the carpet around the B pillar and noticed a nice groove for the cable going across to the centre of the car, so that is why I chose that route rather than follow the sill line upto the glove box.
Im still trying to decide wether to fix the GPS aerial in the rear spoiler as per the OEM unit, It would seem the logical choice, but those that have fitted it behind the head unit seem to be happy with performance but I will make that decision depending on the weather tomorrow.But now I've said all that, I think I will as it will get me another day playing in the X. Well ? what else is there to do on a Saturday ?
I will post up some more pictures as and when the head unit arrives.
I've also got to mention again Rob at Icebox Auto http://www.iceboxauto.co.uk/bmw/e8786-2 ... p-841.html for his patience with my silly questions and excellent comunication. Also worth mentioning that if you buy through his eBay site the units are £100 cheaper than from the web site. http://stores.ebay.co.uk/Iceboxauto/IN- ... 34.c0.m322
Delivery is usually a couple of weeks, but two year warranty and a free reverse camera makes that easy to swallow.
2002 4.4 cooking on gas
n1k85
Re: Hualigan / Dynavin install OEM Nav
Post by n1k85 » Fri Jan 27, 2012 10:57 pm
Nice work mate!
When are you hoping to have the Hualingan?
I was unsure about the GPS antenna too, as most other DIY installs ran it up the side of the dash and just plonked it straight on the top by the window. I assumed this is what John was going to do, but he said it will work absolutley perfectly underneath the dash, totally out of sight!
I've used the Nav about 5 or 6 times since I've had the car, and it's been spot on! So I would certainly not bother running it anywhere else in the car, it would be a waste of time and energy IMO :)
The Digital TV antenna is a whole different story though. In my Glovebox I get hardly anything, but up on the dash I got all the channels. So if you're running anything to back, make it the TV antenna instead! :)
Keep the pics coming! Get yourself a 32GB Micro SD card too, they are pretty cheap off ebay/play.com/amazon etc but they take ages for delivery! I couldn't wait but luckily found a cheap-ish one at my local Chinese computer shop! :lol:
http://www.play.com/Search.html?searcht ... 32gb+micro
2004 Silver 3.0D Sport Auto - 20" Le Mans Rims, Gen 4 Hualingan DVD/BT/iPod/SD/Nav Headunit, E70 Rear Wiper Conversion, Front Bosch Aero Flatblades
jaynana
Post by jaynana » Sat Jan 28, 2012 9:23 am
excellent job, extra complicated by that lpg tank ur carrying :)
Ubatoid
Post by Ubatoid » Sat Jan 28, 2012 10:41 am
The Head unit should be here somewhere around the begining of week after next.
Moving on from your comments re the GPS aerial, I seemed to have overlooked the obvious, use the existing one ! The lead will need extending upto the head unit but that is a small matter as I already have an old extension lead from a TomTom external aerial - Result !.
I think I will try the Freeview aerial in the spoiler though. Again I dont have it yet as its commin with the head unit - how long is the aerial lead on your unit N1K ?
n1k85
Post by n1k85 » Sat Jan 28, 2012 2:26 pm
Good idea re the GPS Antenna if its the same connector. IIRC its an 'F' Type fitment on the Hualingan (the same as all the GPS antennas on eBay)
The Freeview aerial that came with mine has loads of cable, i have it looped up in a big bundle in my glove box, but it looks like it should reach the back of the car, its really long!
NIFTY5058
Post by NIFTY5058 » Sat Oct 05, 2013 12:12 pm
Great timing for this post. I too have been looking to upgrade the stereo/satnav/tv on my wife's 2001 4.4i but have been out off by also having the lpg tank in the boot. This post has made my mind up to buy the hualigen unit as seems to be getting good reviews on the site. Looking forward to further posts and any new advice available. Any help would be much appreciated.
Not been in this site for long and this my first post but some really excellent help and comments on the forum. Excellent site with many helpful and friendly guys. Cheers guys.
Ubatoid
Post by Ubatoid » Thu Oct 10, 2013 7:43 pm
Before you dive in and buy a Hualingan - check out the Andrive unit. Although the Hulingan does everything it says it will, its just doesnt do it very well. Ive lived with mine for over a year now and Im seriously looking at getting something else.
