UPDATE: HELP - Fuel Gauge (NOW FIXED)
Posted: Sun Jan 22, 2012 10:39 am
Hi Guys,
When I bought my car back in December it had problem where as the fuel gauge would not go past half full, incorrectly telling me that I had 300 odd miles left and half a tank fuel of diesel. I would think I had loads of fuel left, but then would get the "bing,bing,bing" and 'Fuel Injection System' fault followed by the engine stalling. (Because it actually had no fuel in it...)
I discovered that because it worked perfectly from Full->Half that the 'High Level' fuel sender unit was working ok, but the lower Fuel Sender Unit (with the float at the bottom) that does Half->Empty was not working correctly. I ordered a new one for £67 and fitted it myself.
Fitting was an easy job and over the next few days I noticed the needle had gone past the halfway mark (which it had never done before) and seemed to be working fine...
That was until a few days later when the needle reached the quarter tank mark and showed I had 159 miles left to go. Shortly after I got the "bing, bing, bing" 'Fuel Injection System' error again shortly followed by the engine stalling. Luckily I had a full can of Diesel in the boot, so filled it up and off I went.
Since then I've had the Fuel Sender out again and fiddled around with stuff here and there to try and get it working correctly. Unfortunately the only way I can really check this myself is to drive the car and see if it stalls or not...Which is not ideal. (Although I have my trusty full can in the boot)
I put £50 of Diesel in it last week and have watched the fuel range figure (which I'm aware is just a basic calculation of fuel level/mpg) and fuel needle go down as they should.
Yesterday me and the mrs took the dog out to Shrewsbury for a walk up the Wrekin, on the way back I noticed the Fuel Guage was on a quarter full and the Range displaying 161miles. I watched the guage like a hawk all the way down to 159miles (and taking the drive pretty easily) and sure enough a few miles later and I got "bing, bing, bing" 'Fuel Injection System'
So again I filled it up with the can and put another £50 in at a local station. I just now know that when my car shows a quarter of a tank (159 miles) it really means empty...
That issue aside the car drives like a dream. I've never had a problem starting it and performance has always been spot on.
Then I read a thread on the USA 5 series forum where a guy had the same problem. He worked out that the Fuel Filter was preventing the fuel pump/syphon system from sucking out the last quarter of a tank of fuel. (So instead of the fuel tank being empty but showing a quarter tank, it actually does have a quarter tank in it...it just can't get to it). He claims that repalcing the £15 Fuel Filter has sorted his issue.
Here is a bit of info from the guy's thread: (Interesting Read)
Any help guys?
Ok, for anyone that's interested (anyone who's contemplated changing their fuel pump because they aren't getting enough power at higher rmps, or because your car is acting like you just ran out of gas, but your gauge says you have over a quarter tank left) - I was going to change my fuel pump thinking that would create higher pressure in the return fuel line so the sucking jet pump (siphon) would work to take the gas over to the right side of the tank. I decided first to change my fuel filter since it was only fifty bucks (verses a $250-330 fuel pump) and I have 80k miles on my car anyway, so it probably needs it.
So, after the fuel filter change (without changing the fuel pump) I have ALL my power back through the whole range of rpms! I think my car might be faster now than ever since I've had it (I bought it with 40K miles on it). Also, wha-la! My sucking jet pump is working!!! I think, anyway. I used the hidden OBC test #6 (see wiki for how to do this) to track my fuel level in each side, and now the left side' just got sucked completely dry and all the gas is in the right side (I had a little less than half a tank when I switched my fuel filter.
I'm going to fill my tank up all the way now to see if everything is working right. If the fuel filter solved the problem, the left side of the tank should always empty first.
Now i'm more than happy to do this, I've found the Fuel Filters for £15 and fitting seems ok-ish (but a bit of a PITA). So I thought i'd ask here if anyone has any input before I buy and fit it?A funny thing happened the other night while I was out on the town with my girlfriend and my sister and her boyfriend. On the way driving home (this was before I replaced the fuel filter) I hadn't been paying attention and the fuel level started getting down to quarter tank level. The car started choking and sputtering and I realized we were going to have to hike to get gas (i've had a gas can in my trunk lately... for some reason ) Earlier I had been showing off the little trick I learned with the OBC, and it happened to be running as we were running out of gas. Seeing all that gas in the left side of the tank gave me an idea. There was a median going down the middle of the highway, so I waited until we rolled up to the next intersection and then flipped a hard (sliding) U-turn. All the gas sloshed up over the hump and into the right side of the gas tank, the car stopped choking and took off and we were able to make it across town to the next gas station!!!
Any help guys?
