Retrofit heated seats
Fortiesc
Post by Fortiesc » Fri Jan 20, 2012 7:51 pm
Hello,
Can anyone help, Has anyone retro fitted heated front seats to 2007 e70 with full leather int.
Not sure if they come pre wired with the elements fitted and just need switches and coding
Any help/info much appreciate
5wany
Re: Retrofit heated seats
Post by 5wany » Fri Jan 20, 2012 11:44 pm
I dont think they come with heating element in seat so a strip down (or seats with elements and correct leather colour req).
Not sure on wiring if its in the loom as standard.
I once asked a dealer if BMW front heated can be retrofitted as OEM and told no, its a sh1tty after market job with control buttons on seat side. Though what do dealers know ;)
:music:
Fortiesc
Post by Fortiesc » Sat Jan 21, 2012 11:03 am
Thanks very much for the info.
n1k85
Post by n1k85 » Sat Jan 21, 2012 11:10 am
I'm not sure on the X5 but on the E46 it involves totally swapping the 2 front seats for heated ones, buying a small wiring loom, running it under the carpet, then buying a whole new switch panel and wiring it up.
It's a big job, otherwise I'd want to do it in my X! I really miss my heated seats I had in my last 2 BM's
http://forum.e46fanatics.com/showthread ... t+retrofit
2004 Silver 3.0D Sport Auto - 20" Le Mans Rims, Gen 4 Hualingan DVD/BT/iPod/SD/Nav Headunit, E70 Rear Wiper Conversion, Front Bosch Aero Flatblades
petert
Post by petert » Sat Jan 21, 2012 1:19 pm
I did this on an E53 X5 (see my 'How to' on this topic). That job is easy but you do need replacement seats with the heaters installed, plus a switch module for the dashboard that also has the switches. E53 did not need coding.
I suspect the E70 will be more complex and need coding though I have no direct knowledge of that.
Peter T
JohnH
Post by JohnH » Sat Oct 26, 2013 9:21 pm
It seems from here http://www.cartronics.co.uk/BMW-X5-E70- ... ated-Seats that it is indeed possible to retrofit heated seats to an E70.
Does anyone know any of the details? Is it just a matter of fitting the heat pads and the replacement heating control buttons with the seat controls and coding it all together?
markda
Post by markda » Wed Nov 13, 2013 5:58 pm
Does this mean removing the seat covers?  If so I'd strongly recommend not doing this, you'll never get them to re-fit the same way again.  I had a leather seat cover replaced on a previous BMW and it was never quite the same after and they had a number of attempts at it.
535dboy
Post by 535dboy » Wed Nov 13, 2013 6:59 pm
Which muppet would buy the car and not order heated seats!!
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
markda
Post by markda » Wed Nov 13, 2013 7:08 pm
I hired a X5 35i when I was out in Florida last week.  No navigation, no sun protection glass (which is needed out there), no parking sensors front or rear, no DAB tuner in fact not very much at all but even that had heated seats!  Somewhat ironic given the climate out there!
JohnH
Post by JohnH » Sat Nov 16, 2013 4:43 pm
[quote="markda"]
Removing and replacing the seat covers is east enough if you're careful. I had it done perfectly before.
I'm still looking for a solution on this if anyone has one.
