battery
kellyleekyle
battery
hi
which is the right/best size bosch battery for a 2000 4.4i E53?. Dont have a clue what size is in there at the moment.
janette
janette
X5 2000 4X4i sport Prins VSI conversion. 136,000miles
- Sanj
Re: battery
Bosch S3 is 90ah
Bosch S4 is 95ah
Bosch S5 is 100ah
Any is good but S4 or S5 is best for the 4.4, go for the S5 from EuroCarParts with their discounts mentioned here:
viewtopic.php?f=8&t=3089&p=32451&hilit=Good+to+know#p32450
Bosch S4 is 95ah
Bosch S5 is 100ah
kellyleekyle
kellyleekyle
Re: battery
wont let me purchase the S5 from ecp, it states it wont fit my model, will only give me the option for the S3?
- ianmaney
battery
I'm picking the S5 version up today from ECP with the kind donation of a discount code offered by another member of the forum (brewer) I'm paying £84.55! On the ECP website, just put in the code for the battery, 444770198, and then 'MBCLUB25' discount code at check-out.
Current Cars:
X5 06 3.0d Sport (His)
1 Series 116 SE (Hers)
Current Bikes:
GSX-R1000k6 (His)
2010 Suzuki Gladius (Hers)
Current Bikes:
GSX-R1000k6 (His)
- Sanj
Re: battery
I have the S4 it will fit and then some.
kellyleekyle
Re: battery
On the site it states its only suitable for the 3.0d or 4.6 or was it 4.8 well not 4.4i that was only letting me have the 3S
Re: battery
Halfrauds used to be the same on their battery selector tool until I took the E46 330Cd over to them and showed them what was in there. The tool said the battery was their code HSB019 (same as the X5 3.0d), when actually it was an HSB110 - which is only slightly shorter on the long side, but fits. It would not let me select anything else but the 019. After that they changed the site!! You may have the same lookup database error issue, but with ECP and for the 4.4
There is an S3, S4, S5 and S6 for the 4.4
Link to Bosch Battery site: http://rb-aa.bosch.com/boaa-uk/Category ... lication=1
Link to the Battery Guide download page: http://rb-aa.bosch.com/aa-batterien/gb/en/pkw/index.htm
S3 - S5 info page with download links to get you the actual battery model number and physical dimensions: http://rb-aa.bosch.com/aa-batterien/gb/ ... t_s345.htm
Re: battery
I fitted an S5 in mine only last weekend, its the same size as the BMW original. Mine is a 2001 4.4 so it will fit your car
- ianmaney
Re: battery
I've fitted Mine today and taken a few pictures as i did it if it helps ?
viewtopic.php?f=8&t=3089&start=45
Current Cars:
Current Bikes:
GSX-R1000k6 (His)
Current Bikes:
GSX-R1000k6 (His)
kellyleekyle
Re: battery
hi
thanks everyone, i went ahead and ordered the S5 using the codes provided
all i need to do now is take it to have lpg tank removed for fitting
dirtymonkey29
battery
Are you sure battery is knackered? Have you had it tested?
kellyleekyle
Re: battery
Hi,
Not tested it no, but if I go to the trouble of taking the LPG tank out then I would rather change it so I know I've got a few years before I need to do it again, the tanks been in 6 years so I'm betting it's not been changed since then.
