	Suspention Dis
- StewieG
Suspention Dis
Hi,
Anyone got a dis in or around East London. My drivers side rear ALWAYS lowers itself after being turned off, and there is a clear difference between the height on both sides, when I press the unlock button it always brings itself up, you can see it and hear it.
I had the relay sensor in the back put in butto no avail. Next try is the dis system. Can anyone help?
Peace,
Stew
Peace,
Stew
55 E53 3.0d with Pano roof and full coms pack. Black with Black
				dirtymonkey29
Suspention Dis
Sounds like a leaky airbag
						- StewieG
Re: Suspention Dis
[quote=""dirtymonkey29""]Sounds like a leaky airbag[/quote]
Thanks Dirtmonkey,
Whats the best way to remedy this?
			Thanks Dirtmonkey,
				dirtymonkey29
Suspention Dis
Replace the suspension air bag.  If its leaking/split it can't be repaired, if that's the case I would do the pair at the same time.  If ride height is same on both sides with engine running and the air pump under the spare wheel is running more often than not and 1 side sinking over night then it's deffo not holding pressure.
						- StewieG
Re: Suspention Dis
[quote=""dirtymonkey29""]Replace the suspension air bag.  If its leaking/split it can't be repaired, if that's the case I would do the pair at the same time.  If ride height is same on both sides with engine running and the air pump under the spare wheel is running more often than not and 1 side sinking over night then it's deffo not holding pressure.[/quote]
Any idea the cost to replace both sides? What does the unit itself cost?
				dirtymonkey29
Suspention Dis
From memory £150ish per air spring.  You'll probably get a pair of used ones from partsgateway.  If your handy with spanners it's a DIY job, a google search will find the DIY instructions or an hour a side if your going to a garage.
						- StewieG
Re: Suspention Dis
its going to have to go to a garage. Ive just looked on real oem but ive no idea what im supposed to be looking at. Any idea on a part number?
Thanks in advance DM.
				dirtymonkey29
Suspention Dis
http://realoem.com/bmw/showparts.do?mod ... g=33&fg=50
Item number one...what year is yours? Part number above is for a facelift... Unsure if it's same part number for preface lift
- StewieG
Re: Suspention Dis
DM,
My vehicle is 2005 so is facelift. So it 2 x part number 1 , left and right. Should I attempt this change, or is it best left to people who know what they are doing?
				dirtymonkey29
Suspention Dis
Try and find the DIY for it.  I'm on mobile and can't search too well.  Personally if it was me I'd do it myself  but I'm not bad with the spanners.  I replaced the air compressor on my old 5 series touring.  A garage will probably take an hour a side or 1 and a half hours tops.  Depends on your skill and tool kit.
				dirtymonkey29
				dirtymonkey29
Suspention Dis
About 8 posts down is a link to the DIY
						- Ubatoid
Re: Suspention Dis
Check out these guys, lifetime warranty on air springs
http://www.arnottindustries.com/part_BM ... id162.html
2002 4.4 cooking on gas
