Aux heating enabled - questions
Smeeagain
I enabled AUX heating with my scanner. From that I've read elsewhere Timer 1 and Timer 2 is the start time. But what is 'Direct Mode' shown on scree underneath Timer 2. When I come out to my X5 after the time that Timer 2 should have stopped the AUX heating is still running and Direct Mode is enabled (even though I have set it when I set Timer 1 and 2. Does it just run continuously if I dont get to it to reset it? If so what is the point oif Timer 2?
Smee
Smee
Bargain Bucket
Re: Aux heating enabled - questions
Funnily enough, I've just (i.e. this morning) enabled my AUX heating with my scanner too. I believe Direct Mode means "turn it on now" and it will run for 30 mins.
Timer 1 will turn it on at the specified time (e.g. morning) and run for 30 mins.
Timer 2 will turn it on at the specified time (e.g. afternoon) and run for 30 mins.
Enabling AUX heating with the scanner has made to AUX vent feature unavailable. Slightly unexpected but not the end of the world. I'll just disable AUX heating when spring comes and enable AUX vent when the blistering temperatures of a British summer arrives and I can blast warm outside air into an even warmer interior.
Got to say, I'm delighted with it and it works like a charm. Nice toasty interior after 20 mins although due to a faling battery, I need to keep my car on a battery charger until the new battery arrives.
BMW X5 3.0d M-Sport facelift (E53).
mikem
Timer 2 is a 2nd starting time, not a stop time.
So if you set timer 1 at 9am and timer 2 at 9.30, it wont start at 9 and stop at 9.30, it`ll start a 9, then start it`s 2 timer at 9.30 and hence finish at 10am.
So you only need to set timer 1, it`ll then run for 30mins and stop automatically. The handbook also says you shouldn`t use it twice in succesion without driving in between as it drains the battery too much.
Direct mode starts it straight away for 30mins, just like pressing the on button on a webasto remote.
plowy
so what if like mine it dont run........LOL..
mikem
Use your heated seats and steering wheel instead
- n1k85
Pretty sure I already know the answer to this question, but since I killed my MID stereo attempting a ribbon repair, I've now got a Hualingan SatNav/DVD head unit (not fitted yet).
is there any other way to set the AUX heater timers other than via the stereo? or am I stuck with a cold car in the mornings?
Also, how do you enable the 'direct mode?' is that done through the MID stereo too?
Any help woudl be great!
2004 Silver 3.0D Sport Auto - 20" Le Mans Rims, Gen 4 Hualingan DVD/BT/iPod/SD/Nav Headunit, E70 Rear Wiper Conversion, Front Bosch Aero Flatblades
Johnny chimpo
You could rig up a remote for the aux heating and enable it via that?
Current Fleet:
2005 X5 3.0d Sport......... Now Sold!
2011 Passat Bluemotion
2009 MNR Vortx.... 12k screamer!!!
2012 C220 AMG Sport
2012 C220 AMG Sport
dirtymonkey29
If I ever get my webasto working on 12v I will be fitting a gsm unit from www.danhag.de so I can turn it on or off with a phone call.
bonerp
I had some smoke this morning from under ther front nearside wheel after a short drive. Ive been told its sometimes the webasto burping....nearly shit myself as thought car was on fire....does anyone elses do this? Bmw told me this!
BMW X5 Le Mans Blue Exclusive 2006 Black nappa
Porsche 356 Speedster replica Condor Yellow https://sites.google.com/site/bonerp356/
- ITBarbie
Mine blew out loads this morning but I'm used to it doing that in very cold weather. It does always make me panic a bit as there's so much but hey it's not let me down yet.
2004 Sapphire Black 3.0d SE
MODS
MODS
- Sanj
[quote=""bonerp""]I had some smoke this morning from under ther front nearside wheel after a short drive. Ive been told its sometimes the webasto burping....nearly shit myself as thought car was on fire....does anyone elses do this? Bmw told me this![/quote]
Normal - diesel car Webasto aux heater exhaust comes out under front passenger seat. And should of smelt of burnt oil.
Usually at 7 degrees and below before it will go off (at least on mine).
- Ubatoid
I wouldnt worry, Its just the heater unit burning off diesel. If the units a little tired it can take a few attempts to get going and in that time you get a build up diesel in the burner and when it does light this gets burnt of creating lovely clouds
Check this out.... http://www.youtube.com/watch?v=txo_bvRd6rM
2002 4.4 cooking on gas
- jaynana
waw! come to think of it - it is a loophole that aux fuel burning stuff is not under emission control regs!
i wouldn't mind a spare fuel burning unit which produces mechanical movement instead of heat, to add add a few horses at the push of a button..
- B5tew
I have the aux heater on my car but on the nav screen it says Aux Ventilation. If I set the timer the fan comes on but no heat.
The heater is working as it gets hot when you sart the car on a cold morning and it is puffing out the smoke from the vent under the car.
Do I need to do something else to get it to work ?
2015 Space grey 30d F15
- jaynana
[quote=""B5tew""]I have the aux heater on my car but on the nav screen it says Aux Ventilation. If I set the timer the fan comes on but no heat.
that's the default config of most cars shipped to the uk.
aux vent is useless really.
aux heater - u can get it enabled in the car's computer to get it to run on a timer (similar to the aux vent). alternatively u can get a remote kit fixed to enable it from a remote.
