a weekend of problems - my rear reg plate has just fallen off - fortunately on the drive so i still have it - but appears only to be secured by double sided tape ? Is that standard?
Smee
regsitration plate attaching
Denis O
Re: regsitration plate attaching
Don't think it's standard from the factory. They would use screws and there's probably a couple of holes behind where your plate fell off to screw into.
I use double sided tape which is made for the job from my local motor factors. It works fine.
Tip: To get an old plate off which has been attached by double sided tape use some 20lb fishing line and drag it though the back of the plate.
05 Mercedes SL350
05 Mercedes SL350
Smeeagain
would it secure ok using a hot melt glue gun ? And I don't see any drill holes (unless under the old tape that I haven't removed yet)
Hot melt glue probably won't work. It won't 'wet' the surfaces and won't hold. I've not yet found a glue for these guns that is any good for this type of use.
I had my plates attached with a special double-sided tape that is used for number plates. The 'norm' is to drill holes and screw them on. Not wanting a rust/water entry point, I asked the dealer to use tape instead. It lasted about three years and then began to fail. I also think that the plates look better fitted that way.
I took the plate off, cleaned it up with White Spirit - to get the glus remnants off - washed the plate in soapy water and got some more tape from Halfrauds then refitted it. I think I may have dual-layered the tape to allow for the slight curve in the metal panel. Never had another issue with it before selling it in September.
Got the same on my X6. The front plate had to be warmed carefully with a heat-gun and curved slightly for a good fit.
Onlinelezmtaylor
I always heat the number plate and fixing area with a heat gun before and after fitting it activates the glue.(don't overheat.)
Never have a problem with them falling off.
Lez
Lez
I'm not a fan of using screws either and have always double sided pads. You definitely need to warm the pads and plates (as well as the panel/bumper) to ensure they stick well. With it being quite cold now, if you do just stick them on without a bit of heat they will just fall off again.
- Rusty
Double sided foam tape every time. Stuck my E46 plates on 6 years ago and never had any problems, and he cars kept outside.
Just warm the plates as mentioned and gently bend into shape to achieve the correct profile, then position carefully and stick.
Simples
Simples
Runabout - E92 3 Series Coupe
