4.4 Engine Failsafe Program Help!!!!
swipe
Post by swipe » Sun Dec 04, 2011 5:20 pm
Guys got a bit of a problem with my 4.4 the "engine failsafe program" has come up on the dash. I've run my 1.4 scanner through it and it tells me that codes 131 (Throttle acutator jammed), 132 (Activation throttle actuator), 103 (Function, monitoring, control unit).
I've done some research and found that the throttle body needed to be changed, so bought a brand new part fitted it but still can't get the "engine failsafe program" to clear.
Each time I run the scanner it sometimes clears the codes but it will still flash up the engine failsafe and the car runs really rough, no throttle input from the pedal so the car is undriveable.
I think that once the failsafe program is cleared it should run back to normal. I've replaced to the battery as well and was hoping that while the battery was off it might clear it, but it didn't.
Really need some help guys if anyone knows what I should do, cos if not its a call for a towtruck down to my indy to see if they can do anything?
mattyp
Re: 4.4 Engine Failsafe Program Help!!!!
Post by mattyp » Sun Dec 04, 2011 5:48 pm
i would take it to a indy mate, could me a wiring problem
2002 X5 3.0i gone
2002 X5 4.4i gone
2002 X5 3.0d Current Car
strummer
Post by strummer » Sun Dec 25, 2011 2:02 pm
you probably need to code the tb to the car
swipe
Post by swipe » Mon Dec 26, 2011 10:29 am
Car's at the indy's and he says it should be a plug and play unit, but it's still showing up on the codes the same. He thinks the DME unit maybe at fault been in touch with Jason about this.
strummer
Post by strummer » Wed Dec 28, 2011 7:03 pm
according to TIS a faulty throttle body adjusts the adaptations in the DME unit,these must be reset when fitting a new unit
swipe
Post by swipe » Wed Dec 28, 2011 7:18 pm
How do you reset the adaptions cos my Indy is having trouble doing this?
strummer
Post by strummer » Wed Dec 28, 2011 7:53 pm
looks like you need the bmw progamming software
ratovnik
Post by ratovnik » Sun Apr 21, 2013 9:53 pm
How to solve this problem, how to code the throttle to the car (adapt throttle)?
JimmySpeed
Post by JimmySpeed » Sun Apr 21, 2013 10:21 pm
Very simple - i've done this twice now both times without 'coding' the TB. You do need to clear the codes and then reset the adaptations using some software like INPA, GT1 or whatever you choose. But after that you simply turn the ignition to pos II until you hear the TB stop moving, turn car off for 10 seconds, repeat the process once more, turn the key back to pos II once more and after you hear the TB stop moving that last time, start the car. Works everytime.
I have a spare TB for the v8's if anyone needs one.
ratovnik
Post by ratovnik » Mon Apr 22, 2013 11:52 am
[quote="mobilejo"]
Repeat all procedure with clear the error codes?
JimmySpeed
Post by JimmySpeed » Mon Apr 22, 2013 11:53 am
You only need to clear the error code once, at the start
ratovnik
Post by ratovnik » Mon Apr 22, 2013 11:56 pm
Thanks!
ratovnik
Post by ratovnik » Tue Apr 23, 2013 12:17 am
Is it possible to adapt throttle in DIS program (DIS v44)?
ratovnik
Post by ratovnik » Sun Apr 28, 2013 2:59 pm
I mean how to calibrate throttle in DIS v44 program?
